Question about Mitsubishi WS-55511 55" Rear Projection Television
WS-55511 55in volume turns up by itself & can't switch devices
My mitsubishi WS-55511 55 inch will turn the volume up by itself and you can't make it stop by the remote or tv directly. You have to turn the tv off and then back on, but it will do it again without touching any buttons. It also won't let me switch to a different device, only stays on cable. Then lost complete remote control function, put in new batteries and still didn't work. Picture is still excellent, nothing else seems to be effected.
  • soreo6 Apr 20, 2009
    the volume display is stuck on the tv, and I cannot make it go off, I also cannot turn the volume up or down, through the remote or on the tv.
  • 126 Answers
The remote is not the problem. The switch for volume up on the control panel has become leaky. Very common problem for this generation Mitsubishi. If you don't mind not having the control panel working you can disconnect it and the set will work just fine with the remote. To disconnect the control panel pull the speaker grill, it just snaps off, and remove the front access panel. Once that is done you'll see a cable going to the switches just disconnect it.
Posted on May 04, 2009
  • Anitra Archer
    Anitra Archer May 13, 2015
    Thanks! I never use the switches on the tv, so I'm sure this is the answer for me.
  • Mitsubishi Master
  • 5,569 Answers
To be sure that your remote has failed, look for a TV shop in your area and ask if they have an IR (infrared) tester; these are primitive devices but they will tell you if the remote is putting out some kind of signal.
If you find it is bad, you can buy an original replacement here:
Mitsubishi remote
Posted on Nov 23, 2008
SOURCE:
Volume, device inpute issues
Try new battery's in the remote, and check all volume buttons, one may be stuck down.
Mar 23, 2014 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi big screet HDTV after being on for a minute, the scree pops and goes black with some red lines, then the volume turns all the way up by itself.
Do the self check----if set has been unplugged plug it in and turn on for it to fail----when it shuts off ON THE FRONT OF THE SET press and hold both the menu and input (device) buttons at same time for at least 5 seconds and release both.
Power light will blink a two digit error code like, 1 blink, 2 blinks and pause and repeat it for a total of 5 times.
What if any error code do you find?
Jun 16, 2012 | Mitsubishi WS-55513 55" Rear Projection...
My mitsubishi 55 inch keeps turning its self off
I had this same problem, make sure that the TV is not plugged into a power strip. Also check to see that the sleep timer is not turned on.
Good luck.
Mar 22, 2011 | Mitsubishi WS-55813 55" Rear Projection...
WS-5551 only on/off button works, won't respond to remote at all
take off the speaker grill, you will see 2 wire plugs, turn the tv on, disconnect both plugs, if it now works with the remote then you need to replace all of the front switches, or leave them unplugged and use the remote, if this doesn't work, you have a bad dm board or signal module which could get very expensive.
Sep 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubshi ws-55311 turns on and then turns itself off
no, if blink code the problem is in the TV set--cable will not cause this type of trouble
Aug 27, 2009 | Mitsubishi WS-55311 55" Rear Projection...
No volume
Have you checked to make sure that your speakers are turned on? Most rear projection televisions have both a physical switch and an interal menu option to turn on and off the built in speakers. The physical switch usually is located in the back near the inputs and outputs. It could have accidentally switched off. Under the menu options it may have been accidentally turned off as well.
Sep 01, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Tv wont turn on
ok is in shut down mode kine of proteccion some of the fuses are pico fuses but you may have problem with convergence IC's that what I' check first if that is ok go to HVT .. if U still have problems e-mail me
Mar 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi remote and control panel issue
Did you ever resolve this problem and if you did, what was the fix? My same tv just got out of warranty and I have the same problem. Thanks.
Nov 22, 2007 | Mitsubishi WS-55813 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
328 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
