My screen is broken but otherwise the camera is working properly. I've lost my usb cable long ago, so I just put my memory card in computer when I want to see my photos. So my memory card is full, photos are protected and I tried the little switch on the card but it didn't help. If anyone has this camera, it would be of great help if you could tell me exactly what to do when deleting all photos. I know you press Review button, and then Delete, but what next? Do I go down, up? Please help.
SOURCE: Kodak M853 error message
My first inclination was that maybe the lock on the side of the SD card was on but after you mentioned that it worked in your mom's camera, I don't think that's the case. You may want to check that though. There's a little switch on the side and just make sure that it's switched to the "unlock" side.
The only other thing would be to format the memory card. When you do that, you will lose all the pictures on it. So, if it happens to work in ***********'s camera, I would transfer the pictures you already have saved on there and copy them to a cd before formatting the memory card.
In order to format your memory card, press the menu button, then go into the setup menu. There should be a list of settings. Scroll down to the format option and choose to format the memory card.
I hope this helps :)
SOURCE: Deleting the card.
I put the memory card in my laptop computer and deleted them. I couldn't get them to delete in the camera, they just kept magnifying.
SOURCE: How do I recover a protected album from my camera?
Hello
My
apologies if this message finds you long after posting this problem ,
but I am currently working through a backlog of problems that never got
answered and hopefully this info can still be of use if not now possibly
in future.
Please download Disc Digger HERE.
This is a free tool you can use that works very well and there is no
installation required, just run the program once you downloaded it.
Once
you have connected the memory card to the computer via either the
camera or preferably with a usb card reader , run the program.
On
the program , select the dig deep option for accidentaly deleted files
or dig deeper for a formatted card. Then select the card you want to do
the recovery on and run the program.
The data will be displayed
and you can recover it from there. This will only work if the card has
not been used since the pictures were lost. Save the files to a location
on the computer hard drive and not back to the memory card as this will
overwrite the other pictures that still needs to be recovered.
Some of the properties of the files may become lost in the recovery but the pictures should be fine.
Feel free to ask if you need more assistance.
Kind Regards
Andrea
SOURCE: I had a memory card
Try below link:-
Contains manual and troubleshooting!
http://wwwuk.kodak.com/global/en/service/publications/urg00512toc.jhtml?pq-path=8815
SOURCE: Its telling me memory card
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
