The loss of the stem is probably what caused the watch to stop. The only remedy is to remove the back cover and identify whether a press-stud or screw held it in place. A press-stud should allow the stem to be simplt pushed back in - although it may need some help by pushing if it's stiff. A screw would likely have loosened, unscrew slightly, reinsert the stem and then screw down firmly. It is unlikely that any parts were lost and if you are not comfortable opening the case, refer to a watch maker (rather than a jeweller) who will do it for you and also assess whether any damage had occurred to start the problem off.
Device code lists are generally listed in the back of the units manual. Depending on the device you want to program the remote to operate, you will need to enter that said device remote code into it using the code entry configuration which is usually to press device button+enter+code
My company carries a replacement battery for the MX3000. The p/n for our replacement is PC036067-(V1 or V3 suffix) You can reach me via email at [email protected] and I will be happy to help you.
1) Please note that the original version, supplied by Universal Remote p/n PC046067-H for the MX-3000, was discontinued by the battery manufacturer. The PC046067-H had a typical capacity of 1800 mah. My company has worked with the manufacturer to provide a replacement that has a typical capacity of 1400 mah but is identical in size to the original although slightly thinner.
2) Universal Remote used two different connectors on the PC046067-H with no deviation of p/n. We carry our replacement with both connectors (our p/ns use suffix V1 and V3 to differentiate). V1 is a simple white plug and V3 is different in that it has pressure tab built in.
I had the same thing happen to me with a Moulinex model 129 lid. Since it is pretty old the part is obselete. I searched the internet and found a replacement part company for small appliances that had my model lid: < AbtecParts.com > and sold it for about the same as the original manufacturer value of the part $10.00. Perhaps they have your lid or you can find a similar replacement company out there. Doesn't hurt to search sites like ebay also where you might find a cheap used one for parts. Good luck.
There are three important considerations concerning this battery.
V1
There are two important considerations concerning this battery.
V1
