I purchased the Yamaha HTR-6130 about 3 months ago, but now the front right and left speakers have no sound. I checked the wiring, tested the speakers by switching to another termianl and went completely through the instruction manual on setup (including reintialized the receiver to factory settings) without any results. Should I send back under warranty or is there any other settings or testing I might have missed? Any help would be appriciated.
Thanks
DWT
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Our Yamaha 6130 - 5 Channel setting was not playing through our L Front & L Surround Sound Speakers. We realized that when buying our new TV we forgot to connect a simple audio/visual cable between the DVD Player and Receiver. When we plugged the RED audio/visual cable to the Coaxial input on the DVD Player & Receiver, it worked!
Thanks i appretiate the help
Look at the same model I was posted earlier how to initializer the receiver however this unit require to update firmware if your unit is still under warranty bring back to Yamaha or service center for Yamaha they will update for you. Due to confidence I can not post that update for you
Cheers
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-6130-Receivers-manual/id/15220bh542/t/2/
same problem here
same here there is sound in the surround speakers, the center and the sub but nothing in the right and left fronts. also i have a 1080 up convert dvd player and when i run it through the av reciever i have no sound and i keep loosing the picture every now and again. but when i run it staight through to my tv its fine. is there even a tech support phone number? i coulden't find one
I have same problem, no sound from front speakers. Even there is no static sound during speaker check from receiver. ( center one is o.K)
first said check speaker wires, now just turns off after 3 seconds
