Hi All, Can anyone shed some light on this? I have a Kyocera fs-c5400 and a Kyocera fs-c5100 and when I print the same image on both machines they are both showing different toner usages. The Kyocera fs-c5400 shows just short of 40% coverage and the 5100 shows just short of 20% coverage, the print quality is identical on both machines but how can the toner usage be so different? Any suggestions?
SOURCE: kyocera FS-C5016N
when you open the left cover you will see some green plastic things. If you pull these towards the left they will clean print heads and charge coronas.
If this does not fix the problem the you will have to remove the dev and drum units from the machine.
The print head sits on top of the drum unit and can be levered off with the three tabs gently lifted.
the entire print head can be remove once the black cover has been unhitched from the sides.
The print heads are not screwed in and what ever you do DO NOT TOUCH THE SCREWS on the print heads as they are only for density adjustment
SOURCE: White vertical stripe on color images when they're printed
You may have some dust on the imaging window (printer head). Remove the toner cartridges and clean it with some tissues.
SOURCE: Kyocera FS-3900 and FS-4000 Prints very faint. New printers affected
sounds good
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: Hi, moved my FS 3830 and it now says check waste
If you are in Ho Chi Minh City,you can go to Dinh Cao Trading and Service Company at 63 Vinh Vien street district 10 and we'll solve the problem for you.
Testimonial: "We took machine there this morning. Will lwt you know how it goes..."
