Hey thanx Chris, i am sure about speakers these are perfect,however not sure about the phone mute wire,let me check that.Hey thanx Chris, i am sure about speakers these are perfect,however not sure about the phone mute wire,let me check that.
You can't post conmments that contain an email address.
inux: 1. System has been set as “Volume mute”. Please press Fn+ F7 to enable speaker. 2. Please click the Diagnostic Tool icon under the Setting Tab==>System Test==>Audio, and test it. 3. Please restore the system for a try. 4. If it is a hardware related problem, please contact the local service center. XP: 1. System has been set as “Volume mute”. Please press Fn+ F7 to enable speaker. 2. Reinstall the audio driver. 3. Using the support DVD or hard disk partition (requires a recovery partition) to restore the system for a try. 4. If it is a hardware related problem, please contact the local service center.
Thanks for using FixYa. First of all please check that the
speaker cables are not damaged and the connections are secure. Reduce the
output level from any external components connected to the music center. Make
sure the audio input cable is firmly seated in the music center SPEAKER ZONE 1
jack and the multi-pin connector on the other end is firmly seated in the Accustoms
module AUDIO INPUT jack. Check the cables connecting the Jewel Cube TM speakers
to the Accustoms module. To restore communication between the music center and
the speakers turn the music center off for ten seconds, then on again. Check
the connections for any external components. Make sure to select the correct
source for the desired input. Be sure the CD is placed correctly, label-side
up, in the magazine, and the magazine is inserted properly in the music center.
Increase the volume. Check to see if MUTE is lit on the display. If it is,
press the MUTE button on the remote control to un-mute the sound. Disconnect
any headphones. Connect the FM and AM antennae. Check to see if the play symbol
in the display is lit. After pressing the CD key, wait a few seconds before
pressing PLAY. Make sure the magazine is properly inserted. Check to see if
there is a disc in the magazine, label-side up. Display shows a flashing box
for a disc that is label-side down or cannot be read. There may be dirt or dust
on the CD. If so, clean the CD. Eject the magazine and try loading the CD
again. A display message “E01” indicates a mechanical error. Unplug the music
center. Reconnect power and try again. If “E01” reappears, call customer
service. If the CD stuck again as you stated in your earlier
comments, then you need to use a small and long screwdriver to reach the notch. Now turn the media center upside
down so that the "Manual Magazine Release" is in your upper right
hand. Locate the two small rectangular "Open Slots" on the side. You
need to use the top slot. Use the screwdriver and push the little "U"
or "Y" Shaped metal upward which is just below the manual release. The
magazine will come out.
Please do accept the solution if
the issue is resolved or else revert for further assistance.
Depress the volume bottom or rotate the volume knob. When on a Bluetooth phone call, the speaker symbol will mute, but unmute when the call ends. Either rolling the right steering wheel scroll or the volume button on the shifter area will should unmute the radio volume.
speaker protection turned on.it can be happend because of bad power amlifire section.can you remoove the powe ramp board with large heatsink.its very easy to repair.and i can help.
nuwan
Hi, I have a LifeStyle DVD Home Entertainment ctr model # AV 48 Media. The speaker connections in the living room around the center are connected, and working ok. The problem is with the remote connection to other speakers in other rooms. I am using 240 voltage. Please advise how the connections should be.
Hoping to have your response soon,
John Luggya. [email protected]
Thanks
My father does these kinds of things and has done them for over 30 years. I'd have to give him a call. Can you please ask someone else? Thanks and sorry.
No sound ? Make sure the audio input cable is connected to the music center FIXED outputs, the black connector is fully seated in the music center SYSTEM CONTROL 1 jack, and the multi-pin connector is firmly seated in the Acoustimass module jack. ? Turn the music center off for ten seconds, then on again, to reestablish communication between the music center and the speakers. ? Check the connections for any external components. Make sure to select the correct source for the desired input. ? Check the speaker connections. ? Be sure the CD is placed correctly, label-side up, in the music center, and the cover is closed. ? Increase the volume. ? Check to see if MUTE is lit in the display. Press the MUTE button on the remote to unmute the sound. ? Disconnect any headphones. ? Connect the FM and AM antennas , and last but not least. Make sure there is power going to the remote speakers or the unit will not communicate with them. Good Luck
