Print quality is good, b&w copy is good. When i make a color copy the machine makes blue lines or red lines. This is a brand new c280. I made gradiant adjust sverel times. Any idea? (sorry my english is not so good)
Replace the cyan and magenta image units
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: new tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
SOURCE: Prints "blue" on a document that supposed to be "red"
the red color contains the blue and magenta colors so your problem is not printing blue insted of red , your red laser miror is dirty from inside you should open the back of the printer then open the laser scaner then clean it then replace it
SOURCE: i wanna know how to reset the maintenance time konica minolta bizhub 750
bizhub c252 how do you reset enter serial number
