You can download the device drivers from the Sony WEB site.
Select your model notebook and the Windows drivers you require. Please click on this link to the Sony support WEB site :-
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER
SOURCE: my sony vaio webcam not working
if you remember the date on which it was working with webmax you can try windows vista system restore feature and restore the system back to the date it was working on
here is an helpfull link
http://www.bleepingcomputer.com/tutorials/tutorial143.html
further Queries are welcome
SOURCE: i want sound driver for sony vaio VGN-N325E
click this link for download and install this driver also
Thanks
Good Luck
Appreciate to rate as "Fixya"
SOURCE: Motion EYE camera will not
If the Camera Driver in the Computer is missing, the Motion Eye Camera will not work.
You will need to re-install the Camera Driver for the Camera to work.
You can download the Camera Driver from here
Download the Camera Driver to a folder in the Computer, the open the folder where the file is downloaded. After that, double click on the file to begin the installation. Please follow the onscreen instruction to complete the installation. After installing the Driver, restart the Computer. This should fix the issue and the Camera should work normally.
Best of luck.. !
SOURCE: my sony vaio VGN-CR354 is
mostaly need the driver for internal bluethooth on instal cd with drivers
also to download from sony site
or software from itv bluethooth.
look also on http://download.cnet.com
SOURCE: sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
driver about vgn-cr354_r specially that sny5001,, where can i find it???
