If you have forgotten the security code for a Nokia 2600, You can do a master reset to your mobile. It would restore your phone to default factory settings. You can get the master reset code from www.Mobileunlocksolutions.com at affordable cost. All the best mate.
I forgot my nokia 2600c-2 security code i want to reset my phone plz help. i try many times the master code but it did not wok what do i do?.IMEI # - 355724026649323
My phone imei no- 356396021107778
please tell me master code
SOURCE: Forget Security Code
if u have forgot your security code, then all u need is a master code. The master code is a 10 digit number that will always be accepted as if it were your actual security code. The master code is specific to your handset and is generated using the handset 15 digit IMEI number (serial number). The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Simply enter your 15 digit serial / IMEI number into the online tool (see link below). Your master code will then be calculated instantly.
http://www.unlockme.co.uk/master.php
SOURCE: i have nokia 2600 . i forget my security code .
You can Unlock the Nokia 2600 from the Security/Password lock using the Master reset Code,You can get the Master Reset Code at
http://www.wickedunlock.com/nokia-dct-master-code-service/rs11wp10/ and Unlock the Mobile..
SOURCE: i forget my nokia 1661-2
just unlock it or UISETTING with ufs box or jaf ur problem will be solved
