Pioneer PureVision PDP-5030HD 50 in. HD-Ready Plasma Television Logo
Posted on Nov 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Green blnking light on pioneer plasma - Picture does not come on
I went to turn on our pioneer plasma tv and a green blinking light comes on and no picture? Is there a simple fix and maybe a timer or something is on? Do I need a repair man?
Please Help with any suggestions!!
  • jgouveia Dec 29, 2008
    Same problem. Reset never worked. Any other thoughts? Is there a reset button?
Anand Kumar
Level 3:
Genius:
  • Master 2,035 Answers
  • Posted on Nov 23, 2008
Anand Kumar
Master
Level 3:
Genius:
Answers
2035
Questions
Helped
851721
Points
5335
You can try a hard reset : Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck..
1helpful
When I turn on my 50" Plasma TV the light goes from red to green. The Green LED flashes 14 times then solid. There is a white raster but no picture or sound.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Plasma TV won't turn on green standbye light flashes
Unplug the tv, wait a minute and plug it back in. This might reset the unit. Who is the manufacturer? On pioneer plasma sets the colour and variations in the blinking light has a significance. Contact the manufacturer for more details.
1helpful
2answers
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Red blinking light on tv?
unplug tv overnight. if that doesnt work the powersupply is probably bad.
13helpful
3answers
Green spots/pixels at top of TV screen
I have a 50" Pioneer PDP-503MXE with the same problem - the fans don't run. It appears to be a problem with the temperature sensor that controls the fan speed. However, the fans can manually be switched to MAX.
To do this, put the display in standby. Press the 'Menu' button and within 3 seconds press the 'Power/Standby' button. The 'Integration Menu' will appear. Select the 'Option' tab on the right. Scroll down (next page) to the 'Fan Control' option. It will most likely be set to 'Auto'. Press 'Set' to change it to 'Max'. Within a few seconds the fans will run.
At Max the fans are a bit noisey but it will cool the unit down.
3answers
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Problem with pioneer pdp-503HDE
Check that the system cables are properly plugged into the back of the plasma display and the media receiver. You may have knocked them whilst installing the DVD player.
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
