When we copy comming turn on main power on E301-0001
Wish I had better news, but the information I found on this says, "E301-0001 Insufficient light intensity in shading" - the details I've summarized below. See the website listed for a full list of error codes. Best of luck with it!
-------- Quoting --------
When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies.
(1) Check the connection of Flat Cable between Main Controller Board (J5) and Contact Sensor.
(2) Replace the Flat Cable between Main Controller Board (J5) and Contact Sensor.
(3) Replace the Contact Sensor.
(4) Replace the Main Controller Board.
----------- End Quote ------------
Sure hope its just a loose cable...
Mark
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=MF4412
SOURCE: my printer canon 4412 not
hi my printer canon mf 4412 printer is not working it is showing error batten red light showing , display is not showing pls solve problem pls it is urgent
SOURCE: I use a Canon ImageCLASS MF4350d Laser All-in-One
I think that error code means a problem with the scanner/lamp. Any type of Exxx code means the machine needs (repair) service. This is a fairly new product and should still be in warranty, so I recommend you contact your regional Canon service agency.
SOURCE: paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
SOURCE: my canon ImageClass MF6550 only make blank copies
I have copy and pasted this solution from another question I answered from a person with the same issue. Several people have reposnded that this solution helped them very much.
This is either your toner cartridge or more likely the plastic arm that opens the laser shutter is broken. When you insert a toner and close the access door, there is a plastic arm that opens the laser shutter. If this shutter does not open it blocks the laser and results in blank copies. If the arm is broken you CAN open the laser shutter manually and block it open. What you need to do it open the cartridge access door, remove the cartridge and look for a 1/2 inch wide slot running from left to right in the metal frame that is in the back upper section where the cartridge goes. The plastic arm that operates the black plastic shutter is on the right side. If broken you can manually lift up the shutter and "block" it open using something like a folded up scrap of paper. I know it sounds strange but I have used this repair on several of my customers machines and they have all worked fine since. If you can not find or effect the repair yourself at least you will know where to point the service person when they come out to look at it.
Good Luck and Thank You for using Fixya.
