Works fine except the buzzing noise.
SOURCE: 5 mostly green verticle lines on all digitle channels. HD ok.
I just called customer support and my issue is now fixed, to my extreme surprise.
It sounds silly (and a tad embarrassing), but here's what I did:
1) Unplug the TV
2) Wait 30s
3) Plug the TV in
4) Test
Apparently even if the TV is "off" for a few days it never fully shuts down unless the power is unplugged. Not sure if this will help anyone else, but I had the exact same problem others are describing. Good luck!
SOURCE: Distorted image, lines, convergence?
If the pip is fine then the digital board is bad. Have it replaced by an authorized Samsung service center as the hex settings have to be copied from the dmd to the new digital board
SOURCE: Samsung HL-P4663W/HL is making a buzzing noise
Color wheel needs replacement is the most likeliest cause.
SOURCE: tv makes buzzing noise then picture fades and eventualy shuts off
Ur colors wheel is dead,must call tech.for this is very difficult to take out,and replaced have no tv tech. experience.Best to call tv shop service,to replaced this colors wheel,and have warrenty on it.
SOURCE: No picture on my Samsung HL-R4667W TV.
Its your Lamp if you have sound and no picture.
CK the lamp Fan make sure it is running.
Lamps Prices depend on where you buy.$85.00 up to $300.00 Look on E-Bay under Electronics/ Lamp number-BP
Mats Electronics has them for $99.00
1-800-628-1118
remove your Lamp and look in middle of it,that will tell you if it is busted.
