Computers & Internet Logo
Bill Wildman Posted on May 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My hp pavilion 734n wont power up
The little green light on the back is on push the button noghthing happens
Anonymous
Level 3:
Top Expert:
  • Master 4,961 Answers
  • Posted on May 18, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
4961
Questions
0
Helped
1185163
Points
16067
Open the case and ground yourself then:
1. Make sure all your expansion cards are seated well.
2. Make sure all your power plugs are ALL seated and seated well.
3. Make sure your RAM is seated well.
4. Make sure your front panel plugs are seated well and in the correct
spots.
(Basically make sure something above didn't come loose.)
5. Test the power supply or get it tested at a computer shop if none of
the above fixes it. Just because the green light comes on doesn't
mean it's not dead or dying.
6. Replace the CMOS Battery. (This is rare to stop a boot but it does
happen)
7. If none of the above reveals a solution then your motherboard is dead.
Good Luck!
5 Related Answers
Anonymous
  • Posted on Jul 01, 2008
SOURCE: Power doesn't turn on
Your answer might be here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431078&os=228&rule=21100
AZ-guy
  • Posted on Dec 02, 2008
SOURCE: Hav a pavilion a510n HP
I had a similar problem. Moved a 4-year-old desktop. Got the flashing light and no start. Quick fix is to unplug unit, open up case and unplug the large power connector on the motherboard. (On mine this is marked P1 and has a lock tab on one side that must be held in while unplugging.) Plug the 110-volt power and THEN plug the connector back into the motherboard. Button the case back up and all will be well until the next time you shut the power off to the computer.
The cause of this problem is likely that the battery on the motherboard is nearly dead. The flashing light is a warning to replace the battery. (It would have been nice if they would have put this into the user manual.) When you disconnect the power as described above, you interrupt the low-battery circuit. Replace the battery and all should be well.
Anonymous
  • 59 Answers
  • Posted on Dec 12, 2008
SOURCE: HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
Anonymous
  • Posted on Jun 01, 2009
SOURCE: computer wont turn on
i had the same problem its going to be your power supply it probably burned out. when i changed mine it worked perfectly.
nyilasrobert
Robert Nyilas
  • 627 Answers
  • Posted on Aug 03, 2009
SOURCE: I have an HP Pavilion a384x. It will not turn on
verify on the power suply is a switch with 2 positions 0 and 1
It must be positioned to 1
If not, the power supply could be damaged. It must be replaced
1helpful
Hp pavillion a850y
It is unlikely to be the switch itself. Check that the memory is seated correctly on the motherboard, as it won't boot without it. Otherwise it sounds like the motherboard itself is shot. Sorry for the
My HP pavilion a620n won't power back on when I push button on the front, there is a little green light on the back that went off when I unplugged everthing attached to the back. Could this be a b
it could be a faulty switch or the bad lead connections
test all power and data leads that attach to your hard drive IDE SATA
MOTHERBOARD TO THE HARD DRIVE make sure they have secure dust free connections and are not faulty if its a flat ribbon 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections
a computer needs power and data to travel through every working device and continue its cycle and have a finishing point so any faulty leads will end up with a computer error
make sure the CPU has a secure dust free seating with thermal paste
make sure your ram modules are securely seated with no dust in the sockets also the Cmos battery has charge with no dust in the socket
on some motherboards cmos batteries are soldered in
hope this helps
HP pavilion a705W pc desktop/ on back by power plugin, green light is on, push power button to turn on, light goes out and nothing happens. I opened panels and observed light again on back lite green and...
if you have installed a new hardware, that might be the cause. specially if it is a video card. The wattage of your power supply might not be enough to run the computer. try to remove newly installed hardware such as video card. If there is none, you may try to remove the power for the hard drive and the dvd drive and check if it will turn on. Just bood in to bios..
if that works, then it definitely is the power supply. it cant provide sufficient power to your equipment..
hope that works.
regards.
1helpful
HP PAVILION A 1520N pc DESK TOP does not turn on when power button pressed. has power to end of cord. Power button does not light up. little green light on back by power source blinking green
Bad Power supply. Look on the side of your current power supply and find the wattage rating, and buy one of the same rating or higher. Some place like newegg.
My "hp pavilion a220n" won't power on. ... I was
Pull the power cord out and press the power button on the PC to drain the power for 10 seconds. Then plug the power cord back in and turn the computer on. If still does not work, then the power supply may be blown out and needs replacement.
Check all wires for loose connections--- if the memory was wrong or something, it would still attempt to boot but stop during the POST and start to beep
My hp pavilion a1224n desktop pc will not power up. The power supppy does show a green light on the back but the pc does nothing when I push the power button
I don't know if you tried this, but there should be an on off switch on back of your desktop, which is the switch to the power supply. If you haven't tried it yet, check and see if the switch button on back is in the on or off position. If you are not sure, then press the switch in the opposite direction, and then press the power button and see what happens.
1helpful
HP Pavilion 700 Wont Turn On
verify if at rear is a button with 1 and 0 position
that must be on 1
1helpful
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
