Ran the washer briefly without water and now when I press the trigger the motor only cycles on and off briefly without developing water pressure of any kind,maintaining the trigger pressure has the motor cycling on and off repeatedly. I have tried disconnecting everything and reassembling but results are the same. Any ideas?
SOURCE: I have a Bostitch CAP2000P-OF 6 gal compressor.
Something is wrong with your "unloader" I should think. That is the device that removes the pressure from the cylinder so the machine does not have to start up against its full air pressure
There will be a narrow air pipe connecting the compressor to the switch assembly which bleeds off the air when the power is off. That hiss you get when you turn it off or it turns itself off.
I think you will find a leak there or possibly the non return valve that stops all the air escaping when the unloader valve is open has failed or got a foreign body stuck in its seating.
Been told by FixYa to add more details as no solutions forthcoming and if I dont they will remove my question,Dont really know what more I can add as I covered pretty much everything.It is only second time I have used the washer and will be disappointed if it is a terminal problem.if anyone out there looking at this problem would like to advise on what other deatils might be useful to arrive at a solution,I would be glad to provide them.
Well people I'm at a loss as to what to do,do I write off this pressure washer after two uses?Are these little guys really so hard to fix when they break! Am I possibly mistaken that it was running it without water that could be the problem?
