Question about Bunn NHB Coffee Maker
I lost my directions to my bunn coffeemaker. Can you tell me how to make the first cup of coffee in a bunn? Is there just one place to pour the water? Fo you leave it plugged in all the time?
  • 125 Answers
It has a reserv tank equal to 2 pots which are hot all the time
the power switch is only for the warmer plate
you get out about what you pour in,
Posted on Dec 14, 2008
SOURCE:
How do you clean bunn tim hortons original coffee maker 8 cup
You should be able to get cleaning material in the shop where you bought the machine or in the supermarket, I am sorry I am not familiar with what exactly you can buy inyour neighboorhood. Kolbrun
Sep 16, 2013 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Overheating water boiling dry
if it is not adjustable you will need a new thermostat. Any bunn service centre should be able to help you out or if the coffeemaker is older it might be worth your while to buy a new one.
Sep 06, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Should I leave the Bunn Pour Omatic Coffeemaker plugged in at all times?
Yes, the coffee maker keeps a tank of water pre-heated, that is what allows it to brew coffee in a couple of minutes. The exception would be vacation (away from home) or other times when you won't be using it for a few days. Visit www.bunnomatic.com if you have lost your user manual.
Dec 31, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn coffeemaker starts before water completely in reservoir
You might try this first. Remove the entire top lid and remove the clear suction cup located near the back of the brewer. Clean this cup with white vinegar and also take your deliming tool and place it in the hole where the suction cup was and clean out. If this does not correct the problem, please call customer service with the model and code date. If your machine is 3 years old or less, we can replace it at no cost. If it is over 3 years old, we will replace it at a reduced price.
Oct 06, 2009 | Bunn NHB Coffee Maker
I mislaid my instruction booklet, how do I clean my 10 cup home coffeemaker? Bunn coffeemaker purchased from Tim Horton's.
With your brewer still turned on and full of water, pour 1 quart of white vinegar into the top and place the decanter on the base and close the lid. Allow the vinegar to stay in there for 2 hours. Then you will need to flush out the machine with 8-10 decanters of water. There is a manual located on the website www.bunn.com. Select @ home then go to products. Select the model and then there is an option to download the manual. Or you can call customer service with the model and code date and a manual can be sent out to you.
Jun 29, 2009 | Bunn 10 Cup Home Coffee Brewer
Bad tasting coffee
you can always clean a coffeemaker with vinegar, but always pour in cold, so you can do it twice or more, but dont re-use the stuff you just used, wait till it's cold or just use some other.after use clean by let water through 2 or 3 times, (also only cold water)
Jan 28, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Bunn auto coffee maker two warmer, only makes about 3-4 cups
The machine will allow you to brew from 4-10 cups. It works on a displacement systems so if you pour in 4 cups of water, then 4 cups of coffee should come out. If it isn't, then get the model and date code from the bottom of the unit and call customer service. If you machine is 3 years old and less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced price.
Dec 02, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Lost manual need cleaning instructions
You can download the operating manual for your machine in pdf format right to your computer from www.bunn.com By the way, I wouldn't personally put vinigar in any Bunn machine, as it takes forever to run enough water through them to get rid of the vinigar taste.
Jul 15, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Weak coffee
It sounds like you may have lost the sprayhead. It is under the brew basket (above the place where you put the basket with the filter and the coffee). Sometimes they get loose and you don't realize it and it can fall in the grounds and get tossed out after brewing.
Jun 13, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Warming Plate
actually the warming plate have heating element... they stop working only when the heating element gets open circuited or wire to that plate gets cut....
Jan 31, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn NHB Coffee Maker Logo
113 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
