How do I turn off the delay start? It seems to default to a random number (e.g. 20 Hrs) and I have to cycle to 00 and quickly shut the door. The manual is no help
Thanks
Likewise, mine defaults to 15 hours every time. Adjusting the time to 00 then immediately closing the door is how I get round it.Likewise, mine defaults to 15 hours every time. Adjusting the time to 00 then immediately closing the door is how I get round it.
You can't post conmments that contain an email address.
Press the key to set the delay start time.This dishwasher can be delayed to start for 1 to 24 hours,and the display window beside the delay key can indicate the remaining time. If you want to cancel the delay start, just press the delay key to make the remaining time become 0.
this is not from me but i found it and am passing on..
Hi
Thanks for using FixYa. Error code 4h means 4 hour delay start which means that the dishwasher is in delay start mode and has been set to 4 hours. You can either wait for 4 hrs or to start it immediately press the cancel button to cancel the delay start option. After this program the cycle and options and press Start again as the dishwasher will not start the wash until it reaches the delayed hour i.e. till 4hrs. If after 4 hrs still the light blinks and it wont start then you'll have to replace the control panel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Delayed Watering
You can delay the first watering cycle of each watering zone by up to 12 hours by using the small button at the bottom middle of each zone area. Press the delay button 1 time for each hour you wish to delay the first start time. The "Low Battery" light will illuminate when you press the button. The maximum delay is 12 hours.
For example, if you are programming at 4:00 in the afternoon and you want your timer to water every 12 hours, but you want the first watering of the day to start at 6:00 a.m., press the Delay button two times. Without the delay, the first cycle would have occurred 12 hours after the timer is programmed (4:00 a.m.). The delay feature changes that to 6:00 a.m. The timer will then water every 12 hours after that.
To cancel the delay.press the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
Press Start/cancel twice to turn-off the dishwasher without draining.
Setting Ring Delay: The Ring Delay setting determines the number of
times the fax machine rings before it answers. If you have extension
phones on the same line as the fax machine, keep the Ring Delay at a
default setting of 4: 1 Press Function/Set, 2, 1. 2 Press < or
> to select how many times the line rings before the fax machine
answers (00 – 04) and press Function/Set. If you select 00, the line
doesn’t ring at all. 3 Press Stop to exit.
Did you find out how to do it Adam. We are having the same problem :(
