My DVD system has been working perfectly reading both DVD cds and VCD cds. Suddenly it only reads VCD cds only, and cannot play DVD Cds. The display indicates "no disc" whenever I try to play DVD!!
CD [CD] [WMA] [MP3] [JPEG] [VCD]
≥This unit can play CD-R/RW recorded with the above formats. Close the sessions or finalize §2 the disc after recording.
≥ [CD] This unit is compatible with HDCD, but does not support the Peak Extend function (a function which expands the
dynamic range of high-level signals).
HDCD-encoded CDs sound better because they are encoded with 20 bits, as compared with 16 bits for all other CDs.
≥ [WMA] [MP3] [JPEG] This unit also plays HighMAT discs.
≥[WMA] This unit does not support Multiple Bit Rate (MBR: a file that contains the same content encoded at several
different bit rates).
§1 Includes single-sided, dual-layer discs.
§2 A process that allows play on compatible equipment.
≥ It may not be possible to play all the above-mentioned discs in some cases due to the type of disc or condition of the recording.
Discs that cannot be played
DVD-RW version 1.0, DVD-ROM, CD-ROM, CDV, CD-G, SACD,
DivX Video Discs and Photo CD, DVD-RAM that cannot be removed
from their cartridge, 2.6-GB and 5.2-GB DVD-RAM, and "Chaoji
VCD" available on the market including CVD, DVCD and SVCD that
do not conform to IEC62107.
Hi, thank you for trying to assist, but the lens cleaner cd did not work. should i just send it back to the dealers ??
I PUT VCD DISC AND ITS SMOOTHLY RUN THE PLAYER BUT ONCE I PU A DVD DISC IT CANNOT READ...NO DISC
