HP Compaq d530 SFF PC Desktop Logo
Cholie Rose Posted on May 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP D530 HDMI video card
I want to upgrade my video card for my HP compaq d530 cmt, to one that has an HDMI port. Is this possible and if so, what kind of card do I need?
Vishwa Madushan
Level 2:
Sergeant:
  • Expert 191 Answers
  • Posted on May 19, 2012
Vishwa Madushan
Expert
Level 2:
Sergeant:
Answers
191
Questions
0
Helped
36814
Points
516
Check ur motherboard manual
5 Related Answers
Beni S-P
arben pllana
  • 1006 Answers
  • Posted on Apr 11, 2008
SOURCE: 5 beeps HP Compaq d530
5 Beeps
CPU or motherboard problem
Anonymous
  • 849 Answers
  • Posted on Nov 27, 2008
SOURCE: Full Restore of Window XP of HP Compaq D530
u need to use system recovery cd supplied with system. if u dont have, create the same from your computer from recovery partition.
Anonymous
  • 8197 Answers
  • Posted on Apr 08, 2009
SOURCE: i want all drivers of hp d530 cmt pb357ux
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=d530&submit.x=7&submit.y=11
Anonymous
  • 1865 Answers
  • Posted on Apr 25, 2009
SOURCE: ethernet driver for hp compaq d530
Drivers are located here: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316715&lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713&taskId=135
You must select the appropriate operating system for your application
Gil Davis
  • 157 Answers
  • Posted on Jun 04, 2009
SOURCE: Ineed hp compaq d530 driver
The driver is available on the HP website. I believe it's a broadbent The PCI SFF modem should be easy to come by. Try this link:
http://www.pcliquidations.com/item.asp?id=3694&referid=160164167166161
$20 bucks.
Your ethernet board is a Broadcom. Here's the link and just select your operating system:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=316715&prodTypeId=12454&prodSeriesId=316713&swLang=13&taskId=135&swEnvOID=1093#11395
Hopefully the entire link will work...but if you go to hp.com, go to the support section and type in your model number and you'll find it.
How i can upgrade my bios version to change or improve the speed of my computer
I need help in re-setting the proper BIOS setup for my HP Compaq d530 CMT (DC577AV) desktop computer. I used the Set Defaults option and need to set all settings back to where I was before the Set Defaults, but don't know the proper settings. Where can I get a detailed listing of the proper BIOS setup items? Thanks.. Jerry
1helpful
Time of this report: 5/23/2011, 15:20:31 Machine name: MIRO-PC Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255) Language: English (Regional...
The embedded video chip in this pc or the optional add-on video cards that were offered with it are extremely old models, that are just Dx8 compatible. Win 7 need a video card that is at least Dx9.2 compatible = you will need to upgrade your video with something like
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7189043&CatId=318
2helpful
2answers
I WANT TO DOWNLOAD HP COMPAQ D530 CMT
you can easily download the setup from the following sites
forums11.itrc.hp.com/service/forums/questionanswer.do?threadId
h18000.www1.hp.com/products/quickspecs/11632.../1163
h30499.www3.hp.com/t5/...PCs...HP-d530-CM
ptf.com/vga/vga+hp+compaq+d530+cmt
www.topshareware.com/...hp-compaq-d530-cmt.../downloads
www.user-guides.co.uk/download/hp/hpcompaq/hp-compaq-d530-cmt-manual-placa-
download and install it on your device,it will work just be fine
3helpful
2answers
What graphics card it can used for hp d530 cmt
This HP CPU is compatible with VGA Card "AGP". Like Nvidia Geforce FX5200 128MB Bit or Up, try also RADEON AGP VGA Card Compatible.
Only AGP VGA Card is compatible with HPD530.
2answers
I wonder if hp d530 cmt if it can used a gforce card and whice on
You can use
NVIDIA GeForce4 MX440/8 (64MB, 8XAGP, VGA,
S-video) low profile
2helpful
HP Compaq d530 CMT Desktop Freezes after a while
Is it like that before? If not then probably, a failing component, a short, most likely RAM card (when you happened to check its rated capacity getting low), connection problem.
Also, too much running applications at the same time, hard drive getting almost full, virus. Or borderline hardware specification for installed application.
Check the easiest first. Is this virus? is hard drive getting full? Borderline specification? Add on card contact dirty? Ailing component?
hope it helps
My computer d530 hp compaq
Your video card drivers are most likely the culprit. Go to HP.com, find the drivers and downloads section and get an upgraded video/graphics driver. Either that or you need to upgrade the video card in the computer, not sure what kind of slot or if one is even available for the d530.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
