Kenmore 54501 Dehumidifier Logo
Eric Kenoff Posted on Jan 09, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blinking bucket full light and humidity setting stuck at '01%'
I recently noticed that my Kenmore 50 pint (54501) dehumifier stopped working. If I unplug it then replug it in, it sounds like the compressor (and possibly the fan) is turning on, but after about 1-2 seconds, they shut off and the "Humidity setting" gets set at 01%. They bucket full red light blinks periodically (maybe every second or two). The "energy timer" and "fan speed" settings can be changed, but obviously don't do much without any fan or compressor activity. I cannot adjust the humidity setting at all. If I remove the (empty) bucket the display does not change, but there are some extra beeps that occur. Recently the unit was moved when a contractor was doing some work in that area. Any ideas what the problem could be?
  • 3 more comments
  • Eric Kenoff Dec 20, 2007
    In the end, I took it to sears and I think they fixed it for a pretty reasonable price. It was a while ago so I don't remember the exact price. I think they fixed the display panel.
  • tjsoko Sep 06, 2008
    Same exact problem as EKDIY. If control panel is bad, I'm guessing that is an easy fix: six screws and one ribbon cable. Waiting for reply. thanks.
  • dbonhaus Dec 02, 2008
    Kenmore 54501. Have the same problem with the "01%" error. Thinking about fixing myself and spoke to CSR parts at Sears and they mentioned that most people get the "PWB (PCB) assembly main" part replaced. Does this sound like the 'brains' of the unit? Would like to know if anyone has replaced this and got the unit to work or not? BTW, part is $12 and sounds worth a try! THX!
  • jgolf Dec 31, 2008
    I now have the same problem, e.g., blinking full light, .01% humidity, etc.; am trying to determine from the above msg traffic, was the display panel or the PWB the fix?
    Many thx, jgolf
  • Anonymous Mar 31, 2014
    shows P-1 error code; can't switch to Normal, can't set humidity, panel seems inoperative. Bucket is empty, manually depressing full switch does nothing. second Comfort-Aire unit to fail in under 2 yrs run time; same issue
Geterdun
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 184 Answers
  • Posted on Dec 19, 2007
Geterdun
Expert
Level 2:
Cheetah:
Answers
184
Questions
Helped
97230
Points
244
Yes but i might be late. if you still have this let me know
  • Geterdun Dec 22, 2007
    great sounds like they did the right thing.
The "full bucket" light is blinking- and the
When the Bucket Full Light is on, none of the controls (other than the On/Off) will work. If you haven't
emptied the bucket, do so. Then make sure the bucket is reinstalled properly into the holder. Failure to do this will cause the Bucket Full Light to stay ON. While you have the bucket out, check the inside of it for a float valve. It may be stick in the UP position. If so, jiggle the handle to make it return to the DOWN position.
I hope this helped you and thanks for Choosing FixYa.
My Maytag 45 pint model M7DH45B2A dehumidier stops working before the bucket is full. The bucket is around 20-30% full, the dehumifier will stop as if the bucket if full. I empty the bucket and reseat...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Duhumidifier will not work
Here is a tip that I wrote to help people with just that dehumidifier problem..
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Tyies to Start
It could be a bad compressor, circuit board, or maybe even a sensor or dehumidistat...
Here is a tip about dehumidifiers2_bing.gif that run but do not extract water from the air..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Humidity pad doesn't work
You've posted in DEhumidifier section.
Sounds like you have a Humidifier. Please post there.
Although why you want to add humidity to the tropics is beyond me.
7helpful
5answers
Bucket full light flashing but not full, humidity % shows as 01%
I posted an extended answer to this problem with part replacement info and pictorial. Why hasn't this solution been posted???
venasguy@comcast .net
Kenmore Dehumidifier Isn't Running
It sounds like you have power to the unit but a component is failing to start the system get an AC tech to check it.
1helpful
01% humidity
When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
The compressor is located in the rear bottom on the right side looking at the machine. After you press the start button and the blower fan comes on, bend over near the back of the unit and listen for the "click".
2answers
Kenmore 54701 (70 pint) dehumidifier stopped running
the lowest setting for % of humidity is 35% on that unit... sounds like with all the other errors that the IC board is bad (the Control circuit board behind the displays)
Top Kenmore Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
