I hope I am correct in thinking you need to know what kind of battery you need for your thermostat and how to replace it. If so . . .
Do you have a set of printed instructions on using the thermostat tucked away somewhere? If so, go find it. The instructions should state the kind of replacement battery you need and how to go about replacing the battery/batteries.
If you add the maker of your thermostat by clicking or tapping on Comment and typing in the manufacturer name, I or someone else volunteering to answer for Fixya may be able to find the instructions for you.
8. Replacing the batteries: - please follow these instructions to replace the batteries on your Powerbolt 1000 unit: Remove inner cover plate located above the thumb turn on the inside of the door. Click here to view instructions on how to remove cover. Replace all 4 batteries with quality alkaline AA batteries. (Do not use rechargeable batteries.) Ensure that the batteries are correctly oriented or unit will not function properly.
You can DIY. This WEB site gives instruction for replacing the battery. http://www.everymac.com/systems/apple/ipod/ipod-troubleshooting-repair-faq/ipod-nano-how-to-replace-battery-instructions.html
The MobilePro 900 back up battery is low and should be replaced. The battery is a CR2032 coin-cell battery, which is very common and can be purchased at most department and drug stores.
Refer to section 1-7 of the "MobilePro 900 Handheld PC's User's Guide" for detailed replacement instructions.
The back up battery should be replaced immediately upon seeing the message "Backup Battery Very Low - Your back up battery is very low or missing. Data loss may result from failure to replace the battery very soon. Consult the manufacturer's instructions for directions on replacing or charging the backup battery."
Warning: It is important to note that the back up battery in the MobilePro 900 is not rechargeable, thus, to prevent data loss, it is important to change the back up battery immediately when this message is displayed.
