Question about JBL Marine Audio Wired Remote
I have Model MR-17 JBL Marine unit built into a hot tub. For some unknown reason, I have lost power to the unit. Connections appear intact, but no power. The manual states it might be a blown fuse. How do I replace the fuse? Please advise.
  • Vic Peterson May 18, 2012
    Is there a fuse located inside the JBL stereo? How do you access the fuse for replacement? Could it be another problem that has caused the unit to lose power?
SOURCE:
  • 76 Answers
SOURCE: I am trying to find
You will find the maual you need by using the following link :
http://www.prospecelectronics.com/JBL%20MR6%20manual.pdf
Posted on Sep 13, 2009
SOURCE: Jbl Marine Audio Wired Remote - my screen is
Will a REM 25 remote work with the MR 15 JBL radio?
Posted on Nov 03, 2009
SOURCE: My JBL Marine Hot tub Sterio quit working suddenly?
JBL is at best a low quality marine grade brand of stereo. It is now garbage. I have worked on hot tub stereos for many years, PolyPlannar is the only one that is any good. If it was bought 30 days ago, where's your warranty?
Posted on Sep 10, 2010
Ironfist109
  • 3018 Answers
SOURCE: I am looking for a
  • By no power do you mean you get no response from CD or radio out of the speakers when trying to use the radio? Should this be the case then I'd like you to check a few places.
  1. First look to make sure the wires in the back are not broke or the insulation has somehow been negated.
  2. Next is to check the power wires and ground wire. Look for an inline fuse anywhere between the battery and either power wires. One should always be installed to prevent a surge reaching the head unit so make sure to check for a fuse. Replace if blown with same size fuse, never bigger.
  3. Remove the face plate and notice the reset hole (last hole on the left) Take a pen or other pointed but not sharp item and stick it into that hole and hold for 10 seconded. Then retry.
  4. Make sure the contacts for the face plate where it hooks into the head unit are clean and don't have any grime buildup that would prevent any of the contacts from contacting.
  5. Next you can try removing all power wires and wait for 5 minutes and re-connect. Sometimes this will also reset the unit.
  • I know you asked for a manual. I don't have the exact one. I do have a similar one that I can offer. http://www.premiumleisure.com/Manuals/nov07/Hydro_Spa_JBL_Stereo.pdf
  • Your unit was discontinued and not made for long and this may be a part of why the manual is difficult to find... for free anyway it is. I can say I don't need a manual to help you determine why the unit is not powering on.
  • How are you determining has power but just not responding to the on/off button? A volt meter check to the wires perhaps at the back of the radio? If you get power to the wires at the back of the radio then double check your ground real well because if the ground is good then, at that point, the head unit is bad.
  • If you perform all the tests I stated above and still no dice then the head unit is bad. There is no "code" for the radio so that will not be a factor. It's really a process of elimination.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Aug 04, 2011
SOURCE: I have a jbl mr-145
I have the same model stereo in a brand new hot tub that was having the same issue. To fix it all u need to do is pull the front cover off to access the pump controls and in there you will find a black box where a power cable runs yo the stereo. There are two screws that open a little door in the black box. In there you will need a small flat head screwdriver to move a redswit over to the 110 volts position. Turn the radio on and it should work. That black box just controls the power to the stereo.
Posted on Oct 07, 2011
I have a jbl mr-145 in a hot tub. It keeps powering on and off???
Oct 09, 2010 | JBL Marine Audio Wired Remote
May 31, 2010 | JBL Am/Fm/Cd 180 Watt Marine Audio System
I can't find whether or not The JBL MR-17 will
I have looked at several sites and none say that they do so I assume they don't.Also if a player does it normally says on the front.
Jun 09, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
Jbl marine mr-17 all funtions are frozen
Initially, have you tried a full hard reset? The reset button is at the panel at the back of the faceplate, bottom left side. Of course doing so will also erase all presets and user settings & configurations.
Additionally, pls verify that the multiple contacts pins are clean, free of corrosion and makes a positive contact with its mate at the rear of the faceplate. If the unit is used in a salty environment, it may be necessary to manually scrape of whatever blue green build up develops between the connector pins and the plastic insulator. You can try using an old toothbrush and WD40.
Further to check are:
1. the red, yellow and black wire are tightly connected where they are supposed to be connected. If the unit is used onboard, it might be to your advantage to likewise check the grounding system;
2. one of the rear connector is for a remote, pls likewise check that none of the pins are shorting and no presence of any corrosion.
If problem persists, it may be necessary to seek the services of a qualified professional as this involves opening the unit up and tracing the circuitry of the logic/controller circuit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
JBL Marine Audio Wired Remote Logo
147 people viewed this question
Top JBL Boating Experts
Gene Pitts
DocZachary
DocZachary
JonSnell Electronic
JonSnell Electronic
Are you a JBL Boating Expert? Answer questions, earn points and help others
