Lucent PARTNER18 Corded Phone Logo
sonia Posted on May 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to change an existing password for voicemail
Abe Seye
Level 2:
New Friend:
  • Expert 47 Answers
  • Posted on May 16, 2012
Abe Seye
Expert
Level 2:
New Friend:
Answers
47
Questions
0
Helped
5516
Points
112
That is based on the network you use. The will be a number provided by your network provider you can call to change it. I will advice you call the customer care of the network you use for that number. Or which network?
I need help resetting the password to my Comdial 7260 00 voicemail.
To reset the password on your Comdial 7260 00 voicemail, follow these steps:
  1. Dial the voicemail extension from your phone.
  2. When prompted, enter the default password. The default password is usually "0000" or "1234".
  3. Follow the prompts to change your password. If you are not prompted to change your password, press "9" for the mailbox options menu, then "8" for the password menu.
  4. Enter your new password when prompted. Make sure to choose a secure password that you can remember.
  5. Confirm your new password when prompted.
  6. Hang up the phone to save your changes.
If you are still having trouble resetting your password, you may need to contact your voicemail administrator or Comdial customer support for further assistance.
I am a new employee and don't know the previous password for voicemail on my intertel landline phone.
to change the password, you need the existing password. Ask the IT department for help as they should know what password was previously used, or contact the personnel department to ask the previous employee for their password used.
https://www.google.com/search?q=password+reset+for+voicemail+on+my+intertel+landline+phone
Reset the voicemail password
Contact your wireless carrier to learn how to reset or change your voicemail password on iPhone.
If you don't remember your voicemail password or need to change it, contact your wireless carrier for assistance.
If your wireless carrier offers Visual Voicemail, you can change your voicemail password directly from your iPhone: Tap Settings > Phone > Change Voicemail Password.
you have at&t following below steps:
To reset your voicemail password over the phone by calling AT&T's automated system:
  • Call 800.331.0500 from any phone or 611 from your AT&T wireless phone.
  • Press the option for Voicemail Help, and then follow the prompts to reset your password.
Manual
The phone doesn't have any message capability - it is the central system (KSU) behind it, which can be one of several types. Generally, F981 will get you into the voicemail system, 0000 is the default password, else you will need to know the existing password for that extension, then follow the prompts (8=admin).
Dont know voicemail password
Are you referring to the voice mail on your cell? What company do you have service with? If using cell, you may be able to try dialing 611 and then press the send or call button. then select the option for reset password. (When you received the phone, were you able to put it in your name with your account info? If so, you may be able to provide answers to the security questions with your account to reset your password.) Let me know if this helps.
I have a Meridian M5316 and the there is an existing voicemail on the phone how do I change the voicemail without knowing the current password?
Your provider will have to reset it for you. Phone them and ask for a reset. They may charge you a dollar or so. But that is the only way
How do you change passwords without knowing previous passwords in order to change voicemail greeting??
Actually, even as a technician, you will never know the origonal password.
But you can get in to reset the existing password back to 0 0 0 0.
There are a couple of steps; depending on your voicemail system, voicemail's are done differently, but try this first.
got to a M7310 set
-> dial FEATURE 9 8 3
-> password: 1 0 2 0 0 0 0
-> you should now see ADMIN and under that MBOX, AA, OTHR
press MBOX
-> press CHNG
-> dial the extension of the phones that you need changed
-> you should now see PASSWORD and under it RESET, press RESET (This resets the mailbox back to 4- zero's)
-> hit the * to back up and repeat fopr all the other extensions.
-> hit RLS after all is done and voila... you have now changed those passwords to those mailboxes.
Now when the new users dial F981 at their desks, and dial 0 0 0 0 the first prompt they get is pleasde change password.
Need to set up user voicemail box (new employee)
Go back to your vendor and get the password for mailbox 999 and the instructions to log into it.
The mailbox exists or it wouldn't ask for a password (they're assigned by default), so you need to go to mailbox 999 and chose option 6 1 3 which is mailbox administration reset password. That will clear the password and you can log into the voice mail automatically from the extension by dialing the voice mail access code.
Post back if you have any problems.
Carl
Adding voicemail to an existing extension
You need to build the mailbox in f983
Log 1020000
Mbox
Add or Change.
When you get to mailbox enter the extension # of the new telephone.
When you get to extension number-enter the same extension number.
Top Lucent Lands Phones Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
