This is a tough one...but I'd try to see if you have good electrical connections. Turn off the power at the breaker box...two breakers. Next, check ALL connections from the box to the terminals inside the stove. They should be bright, clean and tight. If this isn't it...the timer unit may be bad.
fitness.manualsonline.com > ... > Jenn-Air Oven Free kitchen appliance user manuals, instructions, and product support information. Find owners guides and pdf support documentation for blenders, coffee ..
Try turning off the power at the switch again and leave it off for a little while, sometimes the microprocessors become confused and need time to re adjust.
My Jenn Air has the same problem with the computer touchpad. The only temperature I can get to work is from the left hand column, 411 degrees. I don't want to waste another dime on this oven. I've read so many complaints from other owners. No more Jenn Air products for me.
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode 1. Intermittent oven temperature sensor or wire harness or, 2. Intermittent contact on power relay board" This doesn't help since it is too technical. What should I do next?
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
sounds like the power outtage fried the clock. unfortunately, none of today's ovens come with a UPS (uninterruptible power supply), sort of like a power box for your computer. if he power goes out, it'll fry the electronics, including the clock.
have a technician come out and test the clock to see if there is power going to it and what voltage is coming out of it. i would suggest replacing the clock.
