Olympus Stylus 5010 Digital Camera Logo
marsha johnson Posted on May 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camera will not turn off or flash pictures
Camera screen is dark
ONE-Touch-Solution
Level 3:
  • Master 1,679 Answers
  • Posted on May 16, 2012
ONE-Touch-Solution
Master
Level 3:
Answers
1679
Questions
Helped
405050
Points
5442
Fix the Camera yourself
Click here - > Troubleshooting Issue
Regards,
Suhail
2answers
Kodak c875 digital camera: flash has stopped working and not able to take pictures in dark. flash on icon comes on screen but pictures are dark and no light flashes may be need to replace bulb but how and...
Replacing the flashtube is not something you can do. It requires complete disassembly of the camera and delicate soldering skills. It must be sent to an authorized Kodak repair facility. It will cost a lot.
5helpful
The problem is that u know the sony hdv xr500x when u put it on the picture is very dark we have tried it under light too put but the picture is still dark
Hello
When you look at your pictures are they dark, murky and hard to see? If you took pictures at a wedding, dance recital, theater performance or any indoor event and they came out dark, read on to learn why your pictures are dark, and how to fix this common camera problem.
Many people take pictures of indoor events, only to be unsatisfied with the final outcome of their photos. Although you may have bought the top of the line film or digital camera, there are a few limitations that you need to know about.
To correctly expose your pictures, you camera needs a lot of light. The compact point and shoot varieties adjust for this when you're outside during the daytime, and usually your pictures turn out fine, right? Well, then how come when you take indoor pictures, they sometimes come out too dark? There are two culprits; your zoom function and your flash.
Most compact cameras today offer a zoom function. When I used to work in retail photography sales, the first feature that consumers would ask for is zoom. People love to get close-up pictures without using their feet. Although zoom does bring your subject matter in closer, it also decreases the amount of light that can get into your camera. Essentially, the more you zoom, the less light your camera can receive, and your pictures will be darker.
So, if your taking pictures indoors, in a dark church, gym or other window-less room it is very difficult for your camera to get enough light to properly expose your pictures.
This is when most photographers decide to turn on their flash. The flash on your camera is a great tool to illuminate dark situations that are in close proximity to the camera. Most built-in flash units are designed to allow the light to travel 8-10 feet away in poor quality light and up to 15-20 feet in brighter situations.
What most camera users fail to realize is that although your zoom function is visually bringing you closer to the action, you flash cannot reach that far to illuminate the subject, and your pictures will be dark.
Hope it helps, if so do rate the solution
My flash bulb doesn't work, picture are dark
Do you have it turned off? Is there a picture of a lightning bolt with a line through it? If so, press the button with the lightning bolt until the screen shows a lightning bolt and an "a". Also, do you have the camera set on a scene mode such as night? The flash won't go off in some scene modes.
1helpful
LCD screen of the camera
Turn on the flash by pressing the ok button!
Same as posted - picture is way too dark when using flash. Help!
Try a camera reset. Go into the setup menu and scroll to "reset" and follow the on-screen instructions.
2answers
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
