The cord does't return back, it is off. I pull it out until the yellow and red mark, and I felt a noice and then it stop working
SOURCE: Hoover Bagless Windtunnel - Self Propel feature not working
I have the same problem with ours. If you lift the vacuum by the handle it breaks the lever on the transmission. You can find a replacement cable and lever on line for about $16.00 it is somewhat involved to repair but can be done by someone with mechanical ability. You can try and find a repair shop but be careful, they sometimes tell you the part is not available and try to sell you something else. I think they should be able to do the job for aprox. $80.00, but they may want more. I did it myself plus the height adj. knob for $24.00
SOURCE: Hoover S3630 WindTunnel
Solved. I downloaded the exposed view of the Hoover and located the screws.
SOURCE: replacing a fraayed and twisted power cord on a Hoover windtunnel upright
ok so I took this vaccum apart completely except for the electrical and motor systems. It seems to me that without dismantling both of these systems on the vaccum you can't replace the power cord. And I wouldn't recommend taking them apart unless you know what you are doing since replacing the power cord seems to require cutting the old power cord and soldering the new one onto the old terminals. All in all its probably easier to get a new vaccum altogether.
SOURCE: Hoover Windtunnel Tseries cord pulled out too
In the case of where you have decided to "fix" it yourself the best thing is to make small drawings of what goes where as you take things apart. Lay out a white towel and put all the parts on it in the order you removed them. To keep from loosing screws you can screw them back in their holes you took them out of, or lay them in order next to the part you took off. Sometimes there may be longer screws. On your drawings indicate where they go. You don't have to be an artist, just as long as you can understand what you've drawn. As far as the switch is concerned it's either a safety feature or there is a wire pulled part way out and is pushed or pulled back into place when you lean the handle back. Now, understand that there are flat metal "clock" springs that are wound up tight on the part the end is attached to. Whatever you do pay close attention to what is going on just as you begin to open the housing up that holds the cord. If the clock spring is attached to something that may come loose as you pull it apart, it's liable to come off of the winding mechanism and completely unwind suddenly. I've had this happen before. And you never know how many times to wind it up in order for it to be able to pull the cord back in the housing quickly like it did when it was working.
SOURCE: cord rewind hoover s3765
Remove the 5 Phillips-head screws carefully without stripping the heads. There are 2 at the front bottom, 2 at the top back (above the wheels), and 1 at the back beneath the dustbin. After the screws are loosened/removed, you can remove the top cover of the vacuum (be careful with the attached wiring harness). Then remove the black plastic cover over the cord rewind wheel, and you can easily remove the wheel. Pull the cord out a bit to give yourself some slack. You should be able to free the jammed cord and then reassemble the vac.
