How do I change the IP address on a Campaq AlphaServer DS10 that uses OpenVMS
First, identify the NIC you wish to change; use: $ MC LANCP <ret> > SHOW DEVICE Next, use the menu driven utility "TCPIP$CONFIG", to set your desired IP address etc: $ @TCPIP$CONFIG <ret> Option 1 - core environment Option 2 - Interfaces (then select your NIC or the IP Addr to change) Option 2 - add/change a Primary address on *** (where *** is your NIC).
SOURCE: No display
hi sucb Clear nvram and replace memory then checked it will work. there is one black button on system board plz locate it and by pressing it put power on after the display comes update the firmware and bios. pls be free for any assist thanks
SOURCE: DS10 with SBS PCI Expansion
Version 7.1-2 is an older version of the OS. I will have to check, but I think that V7.2 will resolve this. What version of TCP/IP are you using? Back in the day when I supported TCP and VMS, there were some timing issues that causes odd behavior. If you can provide the details about your configuration, I can check and get back to you. If necessary, an examination of a forced crashdump may be needed.
A rare opportunity to work with VMS again!!
Good stuff.
Dan
