Camera turns on and seems that all,is working but nothing showing on display
This could be battery issue. however try the link below to fix this issue. This requires a bit of mechanical/technical work which you have to go thru.
Troubleshoot Camera Issue
Regards,
Suhail
SOURCE: I have a nikon cool pix camera that doesn't turn on
When there is nothing happening, it is hard to understand what is wrong.
Do the menus cone on or anything turn on?
If the camera comes on at all, then try setting all the menus to default.
If nothing comes on, no lights, nothing, then you are stuck.
If it will not turn on at all, I would recommend selling it at a site such as Ebay for repair parts, as is. At least you can get some money back, and buy another camera.
Also you may want to consider to call Nikon and trade-in or trade-up your camera for a re-furbished unit (a re-furbished unit will have everything just as it came from the factory. The support-repair department would be the place to get the number and information.
SOURCE: Nikon Coolpix 5400 lines in pix
Yes! Send the camera to Nikon with the service form. It takes about 3 weeks, free of charge.
SOURCE: nikon cool pix p5100 Camera got wet and does not work
OK, I think I might have worked out how to do a DIY repair. I'll get back to you on this once I have sorted out the step by step images and written it up.
SOURCE: COOLPIX L100 Digital Camera: I am using a L 100 Nikon Cool pix. I have videos s...
Hello there, for transferring media from the memory card to your computer it is much better to remove the memory card from the camera slot and use a card reader as the operating system of your computer will detect it as new media found and you can easily drag and drop the files you want to utilize and will save battery on your camera as well.
Get on to Nikon and let them know about it, it is a common problem with the S4. They are fixing the 3500 and others for free.
John.
