I am trying to boot up a newly built system on two Seagate Barracuda 320GB hard drives set up previously on my last system as Raid 0. The Asrock UEFI does not recognize this configuration despite the fact that I went into the Storage Configuration option and tried and enable it. My Settings show: SATA mode selection: RAID SATA agressive link power management: Enabled ASmedia SATA3 Mode: AHCI SATA Boot ROM: Disabled SATA3_0: Not Detected SATA3_1: M4-CT128M4SSD2 (My new 128gb sdd no windows) SATA2_2: ST3320620AS (One of the 320gb HD) SATA2_3: LITE-ON DVDRW LH-20A1S SATA2_4: LITE-ON DVDRW LH-20A1S SATA2_5: ST3320620AS (One of the 320gb HD) SATA3_A0: Not Detected SATA3_A1: Not Detected In the Boot menu, there is no option to boot off of the Seagate hardrives in Raid. Thanks for your help
RAID implementations will vary from controller to controller, and even from bios to bios revision or version for the same controllers.
You should "image" the raid on the old board, then delete the raid on the old system.
In the new system, you need to treat these drives like they are new, blank hard disks. Any partitions will need to be removed, and the RAID created on the new board. Once this is done, you can use your partition imaging software to drop the data back onto the new RAID partition. Seagate I believe has imaging software available in Seatools, or you can use something like Acronis True Image or GHOST.
SOURCE: SATA hard drive issue
Try changing the SATA controller to run as IDE. I can not advise anthing other because you have not listed the model of the gigabyte board, therefor I can't download the manual to advise the correct setting.
SOURCE: PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
It is not a Gigabyte Board, it is the Asrock Z77 Extreme Motherboard. My previous computer had an Asus Striker Extreme which I set up Raid 0 on but now I cant boot using the discs
