Razor E100 Electric Scooter Logo
Posted on May 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It has not been used in a year charged it and when u go on it not going
Adam Fjeld
Level 3:
Genius:
  • Razor Master 1,508 Answers
  • Posted on May 16, 2012
Adam Fjeld
Razor Master
Level 3:
Genius:
Answers
1508
Questions
0
Helped
542654
Points
1761
Check your charger with a multimeter and make sure that its putting out enough volts, also inspect the batteries for swelling, if they are swollen chances are they might be bad
2001 Pontiac Grand Prix doesn't shut off ignition all the way lights stay on
Lock System Does Not Lock
Step
Action
Yes
No
DEFINITION: The lock system will not allow the key to be turned to the OFF lock position.
Did you review the Steering Wheel and Column - Tilt Description and Operation and perform the necessary inspections?
Go to Step 2
Go to Symptoms - Steering Wheel and Column - Tilt
Verify that the lock system does not lock.
Does the lock system operate normally?
System OK
NO - Go to Step 3
Inspect for a faulty lock cylinder or release button.
Is the lock cylinder or release button damaged?
Go to Step 6
Go to Step 4
Inspect the shift linkage adjustment.
Is the shift linkage adjusted incorrectly?
Go to Step 7
Go to Step 5
5
Inspect the ignition switch for damage.
Is the ignition switch damaged?
Go to Step 8
Go to Step 6
6
Replace the lock cylinder. Refer to Ignition Lock Cylinder Replacement - On Vehicle .
Did you complete the repair?
Go to Step 10
7
Adjust the shift linkage.
Go to Step 10
8
Replace the ignition switch. Refer to Ignition Switch Replacement - On Vehicle .
Go to Step 10
10
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
My chair will not charge,chkd all connections,good.chair has not been used or charged for at least 2 years.it is a2009 chair.
Those batteries may be 8 years old and is probably time for replacement. Batteries should be charged regularly or they will die and not recharge if left. Go to a battery store and get them checked out.
1helpful
Is Facebook going to start charging after the new year in 2015?
no is not true just a dirty strategy to make some money and traffic Facebook to start charging 2 99 month It nonsense or this one Facebook Isn Going to Start Charging Users in November.
Have a good one and enjoy the free service.
How do I get the razor to charge. It doesn't last more than 10 seconds. I've only had the razor for about 2 months
If the chafing light acts normal, and you still can't use it for a short time after charging, You should go back to the store. A battery should last at least one year. But if the razor was in the store for one or more years, without any charge, the battery can be bad already.
Please try charging a few times, but is the battery keeps running low in a few seconds or minutes, go back to the store with it.
Controler wont charge
did you clean where the batterries go?
V tech dect 6.0...both my handsets die out when i go to use the speakerphone..Is it time to replace the batteries as I've had these phones for over two years now?
Try to fully charge them first and check for how long do they keep charge. But, yes, for some batteries 250-300 recharge cycles is a life span.
It wont charge at all. I haven't used it for years and when I placed the headset in its case & plugged the case in to charge...it doesn't seem to pick up a charge at all. I hold down the power button...
Your phones battery is faulty,the connections inside has gone open circuit and the cells are completely damaged.It will never take a charge again and the only solution is to replace the battery.
Rechargeable batteries go faulty if they are not used or charged for 6 months plus.
Mar 17, 2011 • Cell Phones
1helpful
Battery charging
If you use it for an hour or so than I would charge it, at least 8 hours. Always charge it at least 8 hours. To find out if the batteries are bad have them load tested.
Top Razor Toys Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Kardoc
Are you a Razor Toy Expert? Answer questions, earn points and help others
