Nikon Coolpix S3000 Digital Camera Logo
Anonymous Posted on May 15, 2012
Coolpix s3000 wont charge from car usb adapter?
Wont charge using cigarette USB adapter. Why?
Anonymous
Level 3:
  • Nikon Master 32,281 Answers
  • Posted on May 16, 2012
Anonymous
Nikon Master
Level 3:
Answers
32281
Questions
Helped
7913423
Points
102259
The battery in this camera has to be removed and connect to an AC adapter to be charged.
  • Rechargeable Li-ion Battery EN-EL10
  • Charging AC Adapter EH-68P
5 Related Answers
  • 102366 Answers
  • Posted on Jan 05, 2010
SOURCE: Can I charge Coolpix S210 via USB cable and wall outlet?
No. In order to keep down the size and weight, the camera does not include the circuitry needed to charge the battery.
Anonymous
  • Posted on Jul 02, 2010
SOURCE: when i plugged it in for the first time to
I faced the same problem too. But I realised that after plugging in the adapter and connecting it to the camera, you would need to press the power button but not turn it on.
Anonymous
  • 11967 Answers
  • Posted on Aug 07, 2010
SOURCE: My Nikon Coolpix S3000 has
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
  • 102366 Answers
  • Posted on Dec 08, 2010
SOURCE: Hi My digital camera the Nikon
Not all computer USB ports put out enough current to charge batteries, especially if you're going through a hub. Try a different USB port if one is available. Otherwise, plug the supplied AC charger into a wall outlet and use that.
Anonymous
  • 6771 Answers
  • Posted on Jan 14, 2011
SOURCE: My Nikon Coolpix S3000 says
The rechargeable battery probably needs to be replaced, I would take it to a camera shop let him have a quick look to make sure the charge light is coming on and try a new battery.
WHY MY NIKON COOLPIX S3000 FLASH NOT WORKING?
okay let mi think....
you cant charge a nikon camera via usb port the usb port is data only
please reply and try to use a nikon coolpix s3000 charger
Please help me, can charge my ; COOLPLIX S300
You cannot charge to battery with the USB cable.
You can get a main charge adapter from a digital camera shop or on the Internet. Try Amazon and EBay.
Can i use another usb wall charger for my nikon coolpix s3000 or can i only use the one that came with it?
Check the output Amperage on the original dedicated charger and what you wanna use as replacement.
Some devices does not like over amperage and others the under amperage...
Otherwise it shouldn't affect anything if you use other chargers.
M using Nikon S3000 digital camera . but i don't know how can i charged my camera
Hi there just remove the battery and fit the battery on external charger which is came with you camera pack. Or you can charge your battery throw USB charger if you have the cable. Thanks.
I have the charger, but lost the book with how to recharge. Please help Thank you.
There is an error in the instructions provided in the User's Manual and Quick Start Guide for the Coolpix S3000 and S4000. The information contained in the manual and guide instruct the user to plug the UC-E6 USB cable into the camera first before plugging into the AC power supply. This process will not switch the camera power on automatically.
Please follow the steps below in this order only * :
1 - Connect the USB cable UC-E6 to the Charging AC Adapter EH-68P.
2 - Plug the Charging AC Adapter into an electrical outlet.
vinayak_nair_4.jpg3 - Be sure that the camera is turned off and then connect the USB cable UC-E6 to the camera.
vinayak_nair_5.jpgWhen the green LED starts blinking slowly after a few seconds, charging has begun. When the LED goes off, charging is complete.
* If the charging light fails to come on at all, please sure to follow the steps in the correct order detailed above. Connecting with the incorrect order may result in a "no led light" situation.
3helpful
How do you charge a nikon coolpix s3000?
It comes with a wall jack that powers the included USB cable. Plug the USB cable into the wall jack and into the camera to charge. You can also charge from a PC if you connect the USB cable to the PC instead of the wall jack.
How do you charge the batteries of your Nikon Coolpixs S3000? I can't find the "hole" where you put your USB in it
There's a cover on the bottom of the camera marked with the USB symbol and the words "A/V OUT". Flip this cover open and connect to a powered USB port.
Hi My digital camera the Nikon coolpix s3000 kept flashing batter exhausted but it wont charge by the computer. How do i fix or charge my camera?
Can I charge a COOLPIX S3000 directly from a PC via the USB lead supplied?
Yes, as long as the computer's USB port puts out sufficient current. Not all USB ports do so. Make sure you're connected directly, not through a hub.
8helpful
When i plugged it in for the first time to recharge battery, nothing happens - no flashing green light - I left it plugged in anyway but it still did not charge Coolpix S3000 EN-EL10 Li-ion battery...
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
