Kenmore 24 in. 15932 Built-in Dishwasher Logo
Posted on Nov 22, 2008
Kenmore Ultra Wash Diswasher - wont move past initial cycle
The dishwasher starts up like normal. It fills with hot water. However it will not move to the next cycle. The dishwasher makes a buzzing sound for 2 minutes and then shuts off. I can then drain it, but nothing else.
Any suggestions on what is causing hte problem? I hate to toss out a good dishwasher if this is only a small problem. However I will not spend several hundred on a repair.
Kenmore Ultra Wash 665.15922 (or 23, 24, 29). Purchased by previous owner in 2002.
  • 1 more comment
  • rcsaes Nov 23, 2008
    i'm having the same problem with my kenmore washer. water comes in and if I hit cancel it will drain. It won't go past the sensor cycle.
  • j_utah Nov 26, 2008
    Found a small plastic piece that got through the screens. That jammed the motor which caused the motor to burn out.
  • espeedy123 Feb 23, 2009
    Hi-
    I believe I have the same problem. Mine is Kenmore model 665. 16582200. Is there a way for me to check the pump for blockage before calling in a repair guy? Thanks!
    Erin
Glenn Bacon
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Nov 23, 2008
Glenn Bacon
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
Helped
4096
Points
19
Motor trying to start. blockage in pump, or bad motor!
  • jowe
    jowe Nov 16, 2014
    currently working same problem. mine runs after draining and filling 3 times. believe it's temperature related. happens more often in winter. add boiling water and try, to see if temperature is fault. Use drain function after failure due to float sensor turning machine off if too full of water.
  • jowe
    jowe Nov 16, 2014
    temperature reference is for machines that shutoff after filling, buzzing sounds like bad motor.
My kenmore diswasher model#363.153221100 when i start the wash cycle starts to fill up with water but then drains the water back out immediately and the wash cycle never starts.
Hello & Welcome to FixYa
This problem is caused when the motor goes bad and needs replacement. The control will fill water and then sends signal to the motor to start a cycle, if it won't work then it will drain the water and so won't start the cycle. However, it can also be a bad door latch-lock assembly as if the control senses that the door is not closed it won't start the cycle. If you hear any humming buzzing sound from the bottom of the unit then replace the motor if not then replace the latch assembly. Please get back to me if you have any other questions.
Kevin
1helpful
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Brand new ultra wash HE stuck in one cycle
Does it fill with HOT water (check after fill stops)? Did Sears install the washer? If so, have them troubleshoot the problem. It's obviously bringing water in. Are there any error lights or codes? May need to replace the control unit.
Jul 14, 2009 • Dishwashers
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
Dishwasher not moving past sensing cycle
humming noise sounds like a solenoid is not snapping in, this is not something that the average or even above average homeowner can fix. Solenoids go bad, they are a moving part that are activated by electricity, can be dangerous to mess with as water and electricity don't mix. Get a repairman or get a new one.
1helpful
2answers
Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
Hot water for dishwasher
Hi thanks for the question. before you start your dishwasher turn on the hot water tap at sinc let the water get hot . then start the dishwasher it will be hot enough for the rest of the cycle. thanks the appliance doc
Oct 06, 2008 • Dishwashers
Kenmore
Make sure you run water in your sink until it is hot before you start the dishwasher. On the newer dishwashers they will fill and drain until the water is hot enough so it takes longer if it starts with cold water. Normal time for a basic wash could take about 45 min.
20helpful
12answers
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
