When i boguht it , it could sync and was warking pretty well. but it has this problem for a while now that i can't sync on my gmail,cant use android market, after a while the on youtube the video stops loading it laggs etc. i have cleared all the cache and my wireless signal is full so i dont understand what the problem is.
SOURCE: i do not have the
This is very simple to sort out. All you have to do is go to your browser open the google webpage and search for the Android Marketplace the result you get will give you a link to download the android marketplace software to your phone.
This will help you get the android market place on your sony ericsson xperia x10 mini pro.
Hope this solution has been helpful?
SOURCE: I have Sony Ericsson XPERIA
hi,
Different network operator's have different settings of GPRS. Therfore, contact your network operator and ask them to send the settings of GPRS. You will receive the Settings via SMS. Install the settings and re-insert the SIM. If they dont have the settings then ask them to tell you the procedure for creating the manual setting. follow that procedure...
Hope this has helped you..
Please rate the answer.
Thanks..
SOURCE: i cant unlock my mums
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlocking.com which is doing good service .....you can approach this website.
SOURCE: how to sign out from
hi satishaswin9. ALL android phones work on the google system . Now if you want to you can sat another rmail as your primary email. if you go to open market you can down load free asvance task manager, next you wmay want to donload lookout mobile security. aLSO MAKE SURE THAT YOUR WIFI isn't on your phone. You will see a lot of lines you can turn they wifi off. Their isn't any way to tell why your battery is draining. You can only test your phone. you may need a new battery it should be cover under the one yeat warranty
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
SOURCE: I'm using xperia x10 mini
I have the same problem. I've contacted Sony Ericsson and it says Market is blocked from SE phones from China. Still looking for a solution
The Sony Ericsson Xperia X10 supports multiple accounts for Gmail, Exchange Activesync, Facebook and other services. Here, we show you how to add and remove accounts on your Sony Ericsson Xperia X10.
Adding an account:
Removing an account:
