Having trouble with 1-2 cups of water remaining in the gasket on this front loading washer machine after each cycle. I did remove the bottom panel and clean the pump filter out, but it's still doing it. We've also run bleach through the dispenser and have done the full sanitize cycle. Any other ideas?
The porthole seal should have drain holes. These may have become blocked. Wipe away any deposits with a soft cloth, and check the drainage holes (possibly slots) for blockage. Unblock if necessary with a slender wooden or plastic probe.
The tiny holes at the bottom of the door seal are blockedcarefull push a small screwdriver through yhem to clear them out
SOURCE: Water dumps on clothes when opening the lid.
It sounds like the seal is loose (worn out) or damaged in any case....not sealing. Calypso's splash a lot and when bleach is used regularly they corrode quickly. To replace the seal you have to get a whole inner lid assy. I also advise not using bleach or at least not regularly.
SOURCE: mold in door gasket
not really but when completed a wash cyc always leave the door open until it cools down, yes this applies e en if you wash in cold water todays modern front load washer mixes both hot/cold
SOURCE: bleach dispenser does not drain water
i just had the same prob i took off the top snap cover for the bleach and saw were the water goes out and it was clogged cleaned it out and it drains great again
SOURCE: Finished Clean Washer cycle and my bleach dispenser full
It's normal for all washers with a sanitize or tub clean cycle to leave diluted bleach in the dispenser
Thank you for your inquiry, Charles!
From my understanding you need to clean your Electrolux front load washer. The best way to clean out your washer is to use a hot water cycle and a cup of bleach. I would also recommend cleaning the front gasket using a water and bleach solution. You can visit a home store to see if they offer any type of washing machine cleaner as well. I hope this information is helpful to you. -Matt
