SOURCE: I need the Mitsubishi VS-55609 remote code for Cox
here you go tey these
Mit ubishi 0 0 9 3 ,0 1 5 0 ,0 1 7 8 ,0 0 1 9
Thanks for usinhg FIXYA please rate our help
SOURCE: mitsubishi VS-55609 distorted Picture Flickers
I have a 55" Mitsubishi Projection TV Model VS-55609, the color is a little off and it has a sqiggle line, please help
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
SOURCE: Mitsubishi VS-55609: No video/audio - just static
You are on the right track. If you cannot see a picture on either antanna A or B then the tuner is suspect.
You may try hooking the cable straight into the TV if you are using a cable box, if not then you should be getting a picture when your other video devices are turned off.
The fact that you get a picture on video tells me that the AV circuits are fine.
Thanks
asnowman
SOURCE: mitsubishi model number vs-55609 will
remove board clean/dry and replace. coolant leaks from bulbs?????
