If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp.
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
DO NOT ATTEMPT ANY REPAIRS, CALL THE FACTORY PHONE NUMBER IN THE OWNERS MANUAL AND FIND OUT WHERE TO HAVE THE TV SERVICED, IF YOU ATTEMPT ANY REPAIRS THEY WILL VOID THE FACTORY WARRANTY. THIS IS CAUSED BY AN ELECTRICAL FAULT INSIDE THE TV, IT SHUTS DOWN AS A SAFETY FEATURE TO AVOID ANY FURTHER DAMAGE.
my 46'' inch tv polaroid lcd has been working fine for 3 years. today my wife and I noticed the tv is shutting off the screen will go black and the power light does switch to red. you can here something inside the t.v clicking but you can turn it on and it will start back fine for 20 minutes then shut off again? Does anybody know whats going out on the tv? let me know
its not the problem with ur electron gun tube or with any picture ic or sound ic. Every t.v. is microcontoller switched machine.
any damage to microcontroller ic that controls the switching will lead to this kind of problem.
0.01% chance of residue EHT voltage would have affected the microcontroller.
or a new lamp. you could first replace the lamp. the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model.
Request bulletin from Fujitsu '[email protected]'
