Question about Amerock 3 Ring Knobs - BP1586
Broken door knob, cannot enter room
The door knob rotates but the latch does not retract; door knob screws are on the other side of the door and not accessible; I removed the hinge pins, but the door won't come out. I cannot slide the latch back with a thin knife or credit card.
  • 3 more comments
  • marysboys Dec 02, 2008
    Exactly as above.  Screws are on the other side, door wont open when turned.  Have taken out pins and cannot get door off.  How to fix?
  • Anonymous Dec 07, 2008
    i have the same problem
  • Anonymous Apr 05, 2009
    same problem, took the knob off, mechanism fell out, still won't open
  • Anonymous Apr 28, 2009
    A have a door knob that when turned, it will turn the latch a little but not all the way. Sometimes the door will open and sometimes not.
  • warner45w
    warner45w Jun 04, 2018
    The Home Depot or Home Depot is an American home improvement supplies retailing company that sells tools, construction products, and services.
    homedepot survey |
    homedepot.com/survey |
    home depot survey
  • 187 Answers
I know I don't need to mention that knobs with an emergency release inside the house are wonderful things. Many function by sliding a nail into a hole in the middle of the door knob, others use the push/turn technique.
First thing to try is pushing the door knob in and then pulling it out while turning it as far as you can in both directions. If a part is worn out or misaligned, sometimes this is just enough to do the trick. If that doesn't work:
Now that the pins are out of the hinges, try working with another person if you can. Don't concentrate all of your efforts on the latch if you haven't been able to access it because of the moldings. Hinges get sticky and may need a good nudge.
Have one person push the door up from the bottom or top with a small pry bar or large screw driver. While this is happening, watch the hinges. They fit together like a jig saw puzzle, there should be play and they will loosen up a bit now. Now you will have an idea of the best way to try this.
Remember, the hinge side is no longer attached, so caution is in order. If you are working from a side without molding, pull out from the bottom and/or top while lifting gently with the pry bar. You can sometimes use a fulcrum and step on the pry bar if you are alone.
If molding is blocking your side, try pushing the hinge side inward. If that doesn't work, Using the pry bar, go to the bottom corner on the door knob side and tilt the door toward the opposite corner as much as possible.
If you can, jam something as sturdy as possible (screwdrivers)above and below where the latch is. With another screwdriver of tool, push directly into the latch and push the handle of what you are using in the direction opposite the door. Give it a good yank.
Try to be observant and creative while doing this. You are looking to try and squeeze out just a little more space. Use any area where you see play. Underneath, along side, up top, where ever.
There will undoubted be some damage to the wood or paint, remove the molding piece alongside the latch. It will be affordable to replace if you are a diy person.
For the others that commented, parts inside get worn and as mentioned above, the shaft has to be aligned correctly. If not, you run into problems like the latch not fully engaging.
Cutting the knob off will be a bit difficult. Even when that is done, it may be difficult to remove the latch and metal burrs are razor sharp. I think I would call a handyman before attempting that. Good luck all.
Posted on Nov 22, 2009
  • 55 Answers
As a last resort, you can use a hacksaw to cut the knob were it meets the base this will give you access to the bolt which you will be able to retract with a screwdriver. you also could use a drill to drill out the screws but that's a little tricky because you have to guess there location and blindly drill them. either method will get you in but take care not to damage any finished surfaces.
Posted on Dec 10, 2008
    New Friend:
I suggest you to go http://www.onlinewholesaleparts.com/ to buy what you need.Last time I bought a toyota door handle.It's very good and they help me a lot.I hope you that can help you.
Posted on Oct 09, 2012
SOURCE:
How do i manually retract - Exterior door stuck closed - removed knobs (levers)
PUT A SCREW DRIVER IN THE HOLE AND TURN IT
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/joe_0ca6379e2eceb740
May 25, 2014 | Kwikset Lido Polished Brass Entry Lever...
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
Recoil spring on craftsman profession 30 Ft cord reel
On the right side of the housing is a cover. In the center is a hex shaped knob. Hold the knob while removing the cover screws. Once the cover is loose release the spring pressure on the knob. Then you can gain access to the rewind assembly. To reinstall, start with 6 rotations of the knob to put the proper stress on the spring.
Nov 17, 2012 | Garden
How to put the striker from a door knob kit back together
i can help you with that...just follow this steps...
1.Remove the old doorknob by taking out the screws that hold it in. You will have to remove the striker separately by removing the screws that hold the strike plate in place on the outside edge of the door. Slide the striker out.
2.
Take the new doorknob, striker, and strike plate out of the packaging and look for the directions. (Most doorknobs are installed in the same way, but there are always exceptions.)
3.
Slide the striker bar into the hole. Insert the screws into the striker plate and tighten.
4.
ake the two halves of the doorknob, and place the one with the male end through the hole in the striker bar. Place the female side of the doorknob on the other side of the door and make sure that it lines up with the male end. Slide the two together. Screw the knob together using the two long screws that came with the doorknob. Make sure that the screws are tight. Make sure that you have the lock facing the right direction. You want the locking mechanism on the inside of the house or room.
5.
Test your work before you shut the door. Make sure that both sides of the door knob turn and the striker bar goes back and forth.
:p
Dec 01, 2011 | Hardware & Accessories
Sitting room door has closed shut and won't open. Hinges are on the other side and I have removed the handle from my end and it appears that a spring in the inside latch has broken.
Now you can put your standard screwdriver in the hole in the middle of the metal where you removed the doorknob, turn the screwdriver, and now your door will open.
Jen
Jan 21, 2011 | Amerock 3 Ring Knobs - BP1586
How to change entry code
First, remove the control cylinder with your "DF59" control key. The cylinder unscrews to remove. Next, turn the knob all the way to the right, and release it.
Step three: Enter the existing code
Step four: Using either the spanner wrench that came with the lock, or a medium-sized flat-tip screwdriver, reach into the hole the control cylinder came out of; and turn the cam inside, about 1/4 turn (as far as it will go), and then back.
Step five: Turn the knob as far as it goes, ONLY ONCE, then release it.
Step six: Enter your new code.
Step seven: Turn the knob (this time, it should retract the latch).
Test it by turning the knob again: The latch should not retract. Now enter your new code and it should retract the latch as you turn the knob. If so, you have successfully changed the code.
Dec 23, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Dec 29, 2008 | Kwikset Professional Door Lock...
Can't close back door without turning the knob
Try taking the knob out of the door and spraying the whole latching mechanism with WD40 or some kind of lubricant. There is a few moving parts in there that can get bound up. Hope this helps. Don't forget to leave feed back.
Nov 26, 2008 | Top Knobs Hardware & Accessories
Amerock 3 Ring Knobs - BP1586 Logo
19,000 people viewed this question
Top Amerock Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an Amerock Hardware and Accessory Expert? Answer questions, earn points and help others
