1 Red Light
Your system indicates this error when only the bottom right part of the
ring is flashing. When you have 1 red light on the Xbox 360, it is
usually associated with an error code you see
on the screen, such as the Xbox 360 error code E74.
Searching for this error code online or in the Microsoft
support site will give you the description and solution. Usually
the problem lies on the DVD drive whether it is the wrong firmware or
lacks a chip.
It may also be a hard drive error which can be resolved
by taking it out and putting it back in or it can be a voltage error
which usually occurs if you have added accessories to it. It is best to
research the error code so you know exactly what to do.
2 Red
Lights
One
of the most common is when two red lights are flashing. No need to
panic if you see only see the Xbox 360 2 red lights. Its sole meaning
is that the console
is too hot and needs to cool down. Power down the system and try again
in a few minutes or if possible after an hour or two.
After
giving the system some rest and playing in a much cooler environment,
you should be back to your gaming in better performance. If the problem
persists however, you may need to have it serviced to have the cooling
issue fixed.
3 Red
Lights
If
you see three flashing lights, you are experiencing the infamous
Xbox
three red lights problem that many other gamers are
frustrated with. You
may also know it as the Red Ring of Death.
At one
point 1 out of every 3 Xbox 360 owners experienced this
problem. This is the one error that you do not want to
get.
This highlights that there is a serious Xbox 360 hardware
problem.
Your options are to send your console back to
Microsoft for repair or to fix it yourself. Be prepared to
spend
a nice amount of money ($140 or so) if you are sending your system to
Microsoft and you no longer have the Xbox
360 warranty.
If you want to try to fix the problem yourself then you can see reviews
of guides that we recommend to show you step by step how to
perform the repair.
4 Red
Lights
If
you have to get any flashing lights on your Xbox 360, pray that this is
the one. If the entire ring flashes, it is a minor problem
that
indicates that the AV cable isn't connected properly or in rare
instances, the cable is damaged. Make sure everything is properly
connected and replace it if It still doesn't work.
one red light is on at the bottom right hand side
