How to clean the canvas of the Bugaboo Frog Stroller
SOURCE: Bugaboo Frog Foam Handle ripped
On Ebay, if you type in Bugaboo on the search field, there is an item called Stroll-air that covers the handle bar. I think it's made of neoprene (like wetsuits) or something that looks like it.
SOURCE: bugaboo frog hood
you have to check out www.myhoodbaby.com for replacement hoods for bugaboo! expensive but ohhhh so posh!!!
SOURCE: Need to fix a Bugaboo Frog wheel
just order new wheels from bugaboo. They cost about $30 bucks each or contact a local retailer to order you some wheels.
SOURCE: How do you open a bugaboo frog pram stroller
To open the Frog, follow the steps below:
Stand behind the folded stroller, ensuring the handle is on the top of the stroller.
Bend down and place your hands on the handle bar, DONT lift the pram, make sure it stays on the floor.
Push the white button on the inside of the left hand side of the handle bar.
Pull both triggers (located inside of the handle bar) toward you and lift the handle up.
Stand up-right, and place your foot onto the bottom of the two axles which you can see in front of you (make sure that you have your foot on the axle which connects the two small swivel wheels).
Whilst you are standing, with your hands on the handle bar and your foot on the axle, push the axle out with your foot away from you and slightly upwards. This should open the chassis up-right. Please note that the chassis will appear to be unstable and move, this will stop the minute that you click on your carseat/carrycot or seat unit.
I hope this helps.
