I changed the the fuse kit, the circuit board and the touch control panel. I can start the program, but about 20 minutes into the program the program stops and the light jumps to clean light which it 7 times blinks pauses and 7 times blinks (pattern). I have to reset then the panel in order to let it do a program again, which then again stops after about 20 and jumps on clean
SOURCE: Clean Light Flashes
I found this post elsewhere. It seems to have worked for me:
Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
SOURCE: whirlpool gu2400 clean light is blinking 7 times
Yes this is a heater fault detection error. The unit may not be heating the water resulting in unsanitary dishes so the unit shuts down in this fault. Also the door may not have completely shut resulting in the heater not working, but everything else does (the heater common line is broken at the door switch. Clear the fault by entering diagnostics with this key dance heated dry, normal, heated dry, normal. All the leds will light, you can then press cancel and try another wash cycle. If fault occurs again, you must repair heater problem.
SOURCE: Blinking Clean Light
run the 'normal' cycle without the hi temp feature
SOURCE: KItchen Aid Dishwasher KUDI01FL Stopped Running and Will not Start
try the reset button sequence i posted in the other question..
SOURCE: Blinking Green Light
I got the blinking clean light x 7 and I ended up resetting the unit and everything was fine thereafter. You can reset the unit by pressing "heat dry" followed by "normal" forllowed by "heat dry" and lastly "normal." Dishwasher reset and went through a 16 minute cycle. After that, it ran fine. here is a linked that helped me.
http://video.google.com/videoplay?docid=-973702559038457901#
