Hi! I was downloading 8 songs at a time, when I tried to put 9th songs it hanged... then I restarted my phn but afterwards I am not able to download anything and when I tries to close the browser it showing the msg " view interrupted download?" I have done the factory settings also but this is also not working... So ultimately I cant remove the items from downloading menu and I cant download anything now :( Please suggest some solution to reset the browser settings or full phone formatting
SOURCE: Nokia 6600
It is necessary to format your phone, because system files regarding your phone boot sector seems got corrupted. There is not enough room in your RAM it leads to your phone at this status. Take important data backup, remove MMC and enter the press four keys i.e. 3.*,green send key and power on key together for sometime and hold it for sometime. Your phone screen will indicate "FORMATING". Your phone will get formatted, then switch off and on it again as usual . Remember to scan your MMC with a good anti virus before inserting it back in phone. During formating don't remove battery and do this process only with enough charged battery. You will be able to send your message then. Do vote this solution....
SOURCE: Nokia 6288 fault
koo73 - you need to do a reflash the software on the phone.
lou75 - you need to have the earpiece replaced and speaker
SOURCE: gprs not working on nokia n72
Try this link to setup the configuration for the internet on your phone:
https://nokiags.wdsglobal.com/standard?siteLanguageId=118
SOURCE: gprs not working on my nokia n72
Dear Mikunj
First of all the error u have said is occur due if there is no proper setting or packet data not available
So first subscribe packet data from your service provider they will send you gprs setting via message,save it then long press 0 key to start gprs (wap) page
Now most of service provider gives free surfing to gprs,so check it with customer care
but if you have already have subscribed packet data & have gprs setting in ur phone & still problem occurs then ur phone's certificates has been corrupted & u have to reinstall it
Thanks
