My phone battery only charges to 22% now, and i know a new battery will not solve the problem because i put another battery in my phone and it was the same.I deleted the "battery stat.bin" file and that didn't help at all. Maybe it's something wrong with the battery sensor. Please provide a solution if you know one. Thanks!
SOURCE: HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
SOURCE: HTC Touch HD heating problem.....
dont forget you should be closing off the programs in the top right hand corner (pressing home or changing program doesnt close the program so make sure you are usually only running about 50%) and yes it is normally hot my friend and i both have one and we have already seen that both our hd's are quite hot on the back but not scorching... the bat should take up to 4 hrs most to charge off a wall and with regular txting and small (1-10 min calls) a couple of times a day and a little bti of web browsing the phone bat should last a day least.... (again make sure in setting wifi is off when not using and under settings/connections tab/com manager that this is all turned off (just to make sure)) especially remember that even closing the web browser in top right hand corner can leave 3g running so click on the 3g icon (depending on provider) on the top tab and disconnect it (also save u data usage)) atm im running for about 2 days off a charge at least and all i have done recently is reflashed my rom off the htc web site and whenever not suing the phone put it to sleep using the top power button (one press but im sure u all no).
Hope this helps! :D (great phone when you learn how to work it!)
SOURCE: HTC Touch Pro totally dead?!?!
Dear Muppets.
Does no one of you realize that when a phone or some other electrical equipment has serious malfunctions it is often more then just hard reset or softreset.
I have an HTC touch until one day I am sure I dropped it on the floor
Then woowwwww all of a sudden it started acting up.
Be honest.
These are very delicate phones and not bricks.
They are not as simple or reliable as a basic phone due to the fact that they have complicated systems like Windows.
Aynone ever heard of Windows crashing a PC.
Woowww you sound surprised.
I cna easily make a lot of money making somthing that looks fancy but that works like ****.
Think of some ideas.
Windows, HTC phones or similar. Any modern equipment made in China
This dont understand why a phone whic cost tihs much money can't bemade reliable.
Well come to think of it
Selling 1 million+ of them at a few hundred dollars each gives me an idea.
PROFIT ABOVE QUALITY.
And still you fools fall for it.
Yes the phones looks cool.
Any idea why DELL have been so big for so long.
They produce PC's and laptops that still work reliably after 5 years.
I am typing this on a Dell 8600 my business work horse
I use it for webdesign, VB programming, hardware testing
And trow it in my back everyday and in the boot of my car when I don't need it.
And it has never yes NEVER given me idea trouble.
I have tried a few other laptops
FUJITSU SIEMENS TABLE PC
Worked for 3 months then turned off and never came back on
guess what happend to it
It sold it for parts for 100 Euro
Also tried a brand new ACER.
Send it back to supplier as it kept turning of while doing remote access work.
If it aint broke dont fix it.
If it is .................. BIN
Look at hte amount of hours and time you have already spend on trying to figure out why your phone does not come on or work properly.
You would have had a lot more fun with your new Nokia by now
I personally would recommend LG Touch phones.
I now a 19 year old who had it and he threw it all over te place.
NEVER a problem with it and working like new.
Well if you know that LG are working with PHILIPS then you know why they are so reliable.
QUALITY above PROFIT.
and then still plenty of profit to make good money doohh
SOURCE: htc hd2,phone battery died,put on charge and turned it
take a look at this link i found, it shows you how to do a soft reset on your htc hd2:
http://www.htc.com/europe/howto.aspx?p_id=297&id=181
HOPE THAT HELPS.
After more investigations,i realized that if i charge the phone while it's off,it goes to 46%,but still a poor battery life.Maybe i should try another battery again.
