Any time the power is shut off on my Bosch Axxis+ washer, it will not show anything but a blank display when it is turned back on. I have done many combinations of unplugging, turning on and off etc. for varying amounts of time. Eventually it will come back up after I "ignore" it for up to 12 hours - presumably after the right combination. If it is not turned off, then there is no problem. I have 16 month old twins who like to play with switches & knobs, so it comes up more than you would think.Any time the power is shut off on my Bosch Axxis+ washer, it will not show anything but a blank display when it is turned back on. I have done many combinations of unplugging, turning on and off etc. for varying amounts of time. Eventually it will come back up after I "ignore" it for up to 12 hours - presumably after the right combination. If it is not turned off, then there is no problem. I have 16 month old twins who like to play with switches & knobs, so it comes up more than you would think.
If your Bosch Avantixx6 VarioPerfect washing machine is beeping and the light is cycling through the spin cycles without any other noise or action, it could indicate a potential issue with the machine. Here are a few troubleshooting steps you can try:
Check for error codes: Some Bosch washing machines display error codes on the control panel when a problem occurs. Look for any error codes or error messages that may be displayed. Refer to your washing machine's manual or the manufacturer's website to understand what the specific error code means and how to address it.
Check the door/lid: Ensure that the door or lid of the washing machine is securely closed. If the door is not closed properly, the machine may not start or may display an error. Open the door and close it firmly, making sure it latches properly.
Check water supply: Ensure that the water supply to the washing machine is turned on and there is an adequate water supply. If the machine doesn't detect sufficient water, it may not start or may display an error. Check the water inlet hoses and the water supply valves to ensure they are properly connected and not blocked or kinked.
Power cycle the machine: Turn off the washing machine and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This power cycle may help reset any temporary glitches or errors in the machine.
Contact customer support: If the issue persists and you are unable to identify the cause or resolve it on your own, it's recommended to contact Bosch customer support or a qualified appliance repair technician.
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
It appears your timer/controller board has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing. I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information. RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell. In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
ur computer is stuck in resume mode and since there are not all the files on harddrive when it went off so what you need to do is this as soon as it powers on at Toshiba screen keep on taping F8 and then select delete restoration data after that it should boot up fine.
Thought these additional details might help as we are having a similar problem.
When the washer is turned on we get a blank screen, then after a bit we see the display flash. After sometime flashing then we see it go to normal and we can run it. It is as almost as if it need to warm up...
We can get the display to show faster, by playing with the knob. However, the machine still needs time before we can use it.
catalog
Apply the reset and check code on my is f21 brushes
