Freezers Logo
Posted on Nov 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rack on freezer is not working - Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Anonymous
Level 2:
Novelist:
  • Expert 124 Answers
  • Posted on Nov 27, 2008
Anonymous
Expert
Level 2:
Novelist:
Answers
124
Questions
Helped
68579
Points
240
Low on freon. buy new . as freon level drops , ability to feed all shelves falls off. the last shelf to freeze is usually the first one to not freeze ,as charge goes away. time for new, cost to fix to great.
Refrigerator problems 2-door freezer door stuck will not open
Good Afternoon friend, I appreciate your post!
Based off what you have described the door on your Frigidaire refrigerator is stuck and will not open. It sounds like you may have condensation on your gasket and it has frozen the door shut. The best thing to do is disconnect power from the refrigerator for four to six hours and that should break up any ice holding the door closed. I hope this is helpful information. -Matt
Why is chester deep freezer making a loud buzzing sound
Have you made sure it is at least a couple of inches away from wall? It could be the metal rack on the back may be loose, or the feet aren't exactly level... Does it only buzz when cycling?
My freezer is not getting cold, but there is frost on the top rack.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
1helpful
The temperature alarm light is on. the temperature is cold emough to freeze bu t some thngs are not frozen especially on the door shelves. the top rack is frosty . while all others are not frosty
maybe you need to reprocess your freezer. theres an compressor oil in the tube causing the abnormality of circulation of freon gas in your freezer. you need to clean up.
Old (!) freezer needs to be cut up to be removed from basement
you need to call someone (hvac company) to recollect it legally. they'll need to install a pierce valve and **** it out to collect it. it's illegal to let it out yourself. 1800 junk might do it for a small fee.
Stopped making ice, motor is running, compressor is working, large blks of ice are forming in the rack above were they should be dropping into the bin
Disconnect the water line from the water control valve to the ice maker to see if it is letting water thru all the time. It should only let water pass when the ice maker is empty.
May 03, 2009 • GE Freezers
Moving a Kenmore upright freezer
there would be a problem if you lay it down. it should be moved up right or max 45 degrees tilt only. oil in the compressor could go to the evaporator and clog it.
front handles could be remove only from the inside. you have to remove the plastic rack of the door and remove the insulation in order to see the bolt holding the handle.
tnx 4 using fixya,
drcool
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
