After reloading windows 7 the fn f5 function does not work, the problem seems to be the on screen diplay that can not be installed
What do you mean unable to install on screen display? Are you saying your screen is blank?
Maybe you need to reinstall the video drivers.
Get online
and got to www.google.com In the google search box type: "IBM
Support" or "Lenovo Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Download and install the Video drivers.
If
you are saying that the system boots up and everything seems to be
running except the screen is blank then try the steps below.
Shine a flashlight on the dark screen to see if you barely
see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be
any kind of monitor even the old big fat crt monitors as long as it has a vga
cable to connect to your computer's vga port. If so that proves your
video card is ok. The video will show on most systems when you reboot
without you having to do anything. Some systems will require you to hit the FN
(Function key) + F1 thru F12. Hold down the FN key then hit the correct
key for displaying on the monitor (F1 thru F12). The correct key will
normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,
then your screen is bad. If you see no icons by shinning the flash light
and nothing shows on the external monitor, then most likely your video card is
bad.
SOURCE: Cannot switch on Wireless Network access for R52
Dear Eleni -Greece,
Please reveive your device manager for any hardware not functioning.
if all the things are fine check you have any hardware switch for wireless on laptop. make sure its turned on.
now go to control panel. network settings if wireless is disabled enable it.
now check the network. hope it will solve your problem
SOURCE: IBM t43 fn f5 does not toggle wireless on.
There are 2 wireless cards for this model. Be sure you have the correct one. Here is a link to download both of them: http://www-307.ibm.com/pc/support/site.wss/MIGR-58597.html#wireless
SOURCE: My T60 ibm wireless connection doesn't work when I
Welcome to Fixya. You can download the driver for your wireless here. The driver supports Windows 95, 98, Me, NT, 2000, XP.
Don't Forget to say Thanks. Thanks for using Fixya.
Get online
If
bad.
