her are some power Adapters listed on amazon. Also, look on the bottom to see what polarity it is (also by mosue over the picture of the adapter in the bottom link (to zoom in)
It does not seem like a problem of the unit. It might be a loose connection of supply code. Keep the supply code pressed to the unit in different directions and see if the unit takes power. If so, replace the supply code. It's not that expensive.
I had similar problem recently. I noticed that I had forgotten to connect the power supply cable to the USB hub, to which my FreeAgent Go was connected to, after I had connected all my USB devices to my computer's USB ports (after I had disconnected everything from my computer in order to isolate another issue). Reconnecting the power supply cable immediately stopped the flashing light and windows recognized the drive.
Don't know how you are connecting yours to the computer i.e. via a USB hub or directly to the computer's USB port. Note that my FreeAgent Go drive requires both USB connectors connected to the computer (or to USB hub). Two USB connectors are on one end and the other end of the cable is connected to the drive/docking station.
