Ive searched throuout the phone and there doesnt seem to be an option to use the memory card as the default place to save music, images and the phone is now displaying a message saying the phone memory is full and to delete files.......how do i get the images, photos to save only to my memory card?
SOURCE: Transferring songs from Phone Memory to a Memory Card
whenever u want 2 transfer songs from someone elses cell 2 yours temporarily change your message settings by going 2 inbox.then go to settings,then go to others.then change the setting memory in use to memory card instad of phone memory.and then start the bluetooth transfer.after d transfer save the song by usual procedure.now u will b easily able 2 save the song.after that u can revert to ur normal setting of using the phone memory instead of memory card by the procedure i mentioned at start.nothing is wrong with your cell so enjoy...
SOURCE: problem with Nokia N72 memory
korakbc switch off your phone.after your hold keys "call button,star button and three button"hold and switch on your phone.
SOURCE: My nokia n72 keeps on saying memory full.....
hie!
if ur cell is displaying the memory full warning, it means ur phone memory is full, try to reduce some software frm the phone memory, and always install the softwares on ur memory card whenever it ask to install the path, while installing a software.
if the problem is still there, of memory full after emptying ur phone memory, then soft format ur cell, by pressing *#7370# and then the security code(12345 by default)
bt before that backup all ur important datasuch as contacts and mesages of the phone memory, as then soft format reset all the settings and flash all the phone memory.
bunty
SOURCE: nokia 6300 memory full unable to receive messages
All you need to do is to check if the message centre number is appropriately configured.you can also check on your service provider
SOURCE: full phone memory even though its not full
please help me!!!!
my nokia 5130c-2 is showing not enough phone memory!!!
when i check how much memory i have left on the phone memory it show's less memory.Basically nokia 5130 have about 32MB memory but it shows about 6 To 7MB memory. All the files that i have recieved through bluetooth is stored in the memory card ...
whenever i change a theme the phone memory gets reduced...
i'm not able to update my music library because of this...
pz plz plz plz help me!!!!
1.
Turn off the phone and insert the memory card into the memory card
slot. Turn the phone back on.Press the "Menu" button on
the main screen and click on the option for "Extras."
2.
Scroll down to the bottom of the list. Click the
selection for "Memory Card."
3.
Select the "Options" icon on the screen. Scroll through
the list to the "Unlock Memory Card" option and press
"OK."
4.
Type in the unlock password in the password field. If you do not
know the password, the default unlock code is either "12345"
or "1357."
1.
the main screen and click on the option for "Fun & Apps."
2.
Navigate to the option for "Gallery" and click on the
"OK" button. Scroll to the "Memory Card" item
and then click on "Options." Scroll to "Memory
Card."
3.
Click "Delete Password" when the window prompt appears.
Make sure the message "Memory card will be unlocked, do you
want to continue" appears. Click on the option for "Yes"
to confirm.
4.
Scroll down to the password field and enter in the default
password. If you do not know the password, the default unlock code
is either "12345" or "1357." Click "OK"
to delete the password from being required.
