Question about Garden
ADJUST TOE OUT ON stx46 JOHN DEER
Front wheels have 3/4 inch toe out
    Brigadier General:
  • 6,468 Answers
Some are fix rods others have a lock nut and threads to adjust
Posted on May 15, 2012
5 Suggested Answers
SOURCE: john deer
Hi if you look on the side of the oil pan there should be a square plate with 4 bolts the oil filter is behind it its a paper one Fram C139PL and a new gasket comes with the filter. I hope this helps. M.L
Posted on May 05, 2009
  • 28 Answers
SOURCE: John Deer 420. Steering not working and
you have lost the steering fluid ,check steering column for wher leaking fluid
Posted on Aug 26, 2009
harlan301
  • 205 Answers
SOURCE: john deer 310 g wont start after it sitts a day
if its turning over check your spark. if you have spark remove the air cleaner and spray some carburetor cleaner to see if it start than stops- let me know
Posted on Oct 14, 2009
wireguy212
  • 1627 Answers
SOURCE: john deer lawn tractor x324 not getting fire to
Igniter module is under the dash held on with one ten millimeter bolt,or dealership has replaced 8 in the last 2 weeks.It is solid black and is above the battery any it has a grey plug in it.
Posted on Apr 19, 2010
Ariens 42" lawntractor front wheels aren't straight
adjust the toe in -out and if they lean in at they top check bearings or king pin wear
toe in should be slightly in at the front(1/8 ") and wheels straight up and down
May 06, 2016 | Ariens 42 in 17.5 HP 6-speed Riding Lawn...
Undefinedright front tire out of line,l-130 riding lawn momer .right front
If the tie rod end has been changed, you will need to adjust the toe in by dropping the tie rod end from its connection to arm. Not the steering rod. Tighten or loosen the tie rod end on the steering rod until there is a slight toe in. Re install the tie rod end into the steering rod. If there is too much toe in, the wheels will spread when in reverse and steering is impossible. It may take several attempts to set the toe in properly. When proper adjustment is met, steering will be easier or as it should be.
Oct 16, 2014 | John Deere Garden
How do you adjust rear end toe
replace anything that was bent and then have the rear end alignment done at a wheel alignment specialist shop
any specialist shop when doing a front alignment should always check the rear first as it controls the accuracy of the front job
Aug 17, 2014 | 2002 Oldsmobile Intrigue
How to adjust toe on 2000 lincoln continental
adjust the tie rod ends to achieve toe-in/out adjustment. Measure across the wheels at the front of the steering tyre and then measure across the tyre at the rear of the steering tyre ( same height) and see what the difference is. Adjust the tie rod ends until the front measurement is smaller than the rear by about 1/8 inch . Lock up the lock nuts on the tie rod ends.
May 19, 2014 | 2000 Lincoln Continental
John deere 145 toe in adjustment
Adjust by measuring between the wheels {metal rim} at the 9 and 3 o'clock positions. I.e, halfway point on the rim at the front and rear. You can measure between the tire, but it is more difficult to get a good, repeatable measurement. If it were an MTD, you could adjust the toe by bending the tie rod/ drag link.
tom
Dec 19, 2012 | John Deere 22HP VTwin 48" Riding Mower
Toe-in, toe-out for mazda bravo 2600,1997 model, dual cab
This must be set on an alignment machine you just can't move the front wheel to what you think is correct, it must be right on. They toe in slightly on most vehicles
Nov 06, 2012 | 2003 Toyota Corolla
Can i adjust bent or toed out front wheel on 82 bronco?
The toe is adjusted by the tie rod ends connected to the gear box.
Some adjustment is possible where the tie rod ends connect.
Jul 13, 2012 | Ford Cars & Trucks
How do you adjust the steering toe on a L130 lawn mower?
The L130 off of the show room floor does not have adjustable drak link / tie rods.
One of the 300 hour inspections is to inspect the steering pivot bushings. You jack up the front from the center and check for play of the pivot bushings by teetering the tie at the 6 and 12 oclock positions. If you get a lot of movement the bushings are bad. If the bushings are ok (I doubt they are) then you can also add adjustable tie rods
1 GY20492 ROD, RH DRAGLINK ASSY. ADJUSTABLE
1 GY20491 ROD, LH DRAGLINK ASSY, ADJUSTABLE
http://cgi.ebay.com/John-Deere-Tie-Rod-Drag-Link-L110-l120-L130-L-Series-/280669312038
They are more expensive at JD ($66.00)
Just note the pivot bushings do NOT show up on any JD diagram but they do exist. Check with JD parts. They most likely know the PN from memory.
http://jdpc.deere.com/pimages/MP29/MP29762________UN16SEP02.gif
Thanks for choosing FixYa,
Kelly
Jul 27, 2011 | John Deere 22HP VTwin 48" Riding Mower
I want to know how to fix the alignment on my 1995 honda accord ex.
Before making wheel alignment adjustment, perform the following checks:
  1. Tires should be equal in size and runout must not be excessive. Tires and wheels should be in balance, and inflated to manufacturer's specifications.
  2. Wheel bearings must be properly adjusted. Steering linkage and suspension must not have excessive looseness. Check for wear in tie rod ends and ball joints.
  3. Steering gear box must not have excessive play. Check and adjust to manufacturer's specifications.
  4. Vehicle must be at curb height with full fuel load and spare tire in vehicle. No extra load should be on vehicle.
  5. Vehicle must be level with floor and with suspension settled. Jounce front and rear of vehicle several times and allow it to settle to normal curb height.
  6. If steering wheel is not centered with front wheels in straight-ahead position, correct by shortening one tie rod adjusting sleeve and lengthening opposite sleeve equal amounts.
  7. Ensure wheel lug nuts are tightened to torque specifications
Ride Height Adjustment
Before adjusting alignment, check riding height. Riding height must be checked with vehicle on level floor and tires properly inflated. Passenger and luggage compartments must be unloaded. Bounce vehicle several times, and allow suspension to settle. Visually inspect vehicle from front to rear and from side to side for signs of abnormal height.
Measure riding height. See figure. Riding height between left and right sides of vehicle should vary less than 1′ (25.4 mm). If riding height is not within specification, check suspension components and repair or replace them as necessary.
Wheel Alignment Procedures
Honda recommends using commercially available computerized 4-wheel alignment equipment. Follow equipment manufacturer instructions to obtain vehicle alignment settings. Use following procedures for necessary adjustments.
Civic Camber Adjustment
Compare camber settings with vehicle manufacturer recommendations. If camber is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck camber.
Civic Caster Adjustment
DO NOT use more than 2 shims. If more than 2 shims are required to adjust caster angle, check for bent or damaged suspension components.
Compare caster settings with vehicle manufacturer recommendations. If caster is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck caster.
Civic Toe-In Adjustment
  1. Secure steering wheel in straight-ahead position. Measure front wheel toe-in. If adjustment is needed, loosen tie rod lock nuts. Turn both tie rods equally in the same direction until front wheels are in straight-ahead position and toe-in reading is correct. Tighten tie rod lock nuts. Reposition tie rod boots if twisted.
  2. Ensure parking brake is released. Check rear wheel toe-in. If adjustment is needed, hold adjusting bolt on rear compensator arm and loosen lock nut. See figure. Adjust rear toe-in by sliding rear control arm until rear toe-in is correct. Install NEW lock nut, and tighten it while holding adjusting bolt.
Wheel Alignment Specifications
  • Camber - Measurement in degrees.
    • Front: 0 (range -1 to 1)
    • Rear: 0.33 (range -1.33 to 0.67)
  • Caster - Measurement in degrees.
    • 1.17 (range 0.17 to 2.17)
  • Toe-In - Measurement in inches (mm).
    • Front: -0 (0)
    • Rear: 0.08 (2.0)
  • Toe-In - Measurement in degrees.
    • Front: 0.00 (range - 0.16 to 0.16)
  • Toe-Out On Turns - Measurement in degrees.
    • Inner: 41.00
    • Outer: 33.50
Torque Specifications Ft. Lbs (N.m)
  • Rear Control Arm Adjusting Bolt: 48 (65)
  • Spindle Nut: 136 (185)
  • Tie Rod Lock Nut: 41 (55)
  • Wheel Lug Nuts: 80 (108)
hope this helps you out.
May 09, 2011 | 1995 Honda Accord
Garden Logo
216 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
