Pool & Spa Logo
Anonymous Posted on May 14, 2012
Summer escapes pool pump won't turn on
My pool pump for my 15 x 42 pool will not turn on. The breaker is not tripped and it is not a problem with the outlet. It was working, I unplugged it and it will not work since it has been re-plugged in.
  • 5 more comments
  • Anonymous May 14, 2012
    Meant to add- only owned the pool for two weeks.
  • Anonymous Aug 31, 2013
    Also same problem - owned pool for 4 weeks!
  • Kerry Dalton
    Kerry Dalton May 20, 2014
    me too.. ours was only up for 2 weeks
  • Rhonda Curry
    Rhonda Curry Jul 08, 2015
    ours only up 4 weeks
  • Jay Ehrie
    Jay Ehrie Jun 30, 2018
    Mine was up for 2 days and the pump went
  • Naresh
    Naresh Nov 01, 2018
    very good post..https://freerobuxhacknosurvey.com/
  • Rene gagnon Mar 31, 2019
    The shafts they come with are porcelain. Go to hardware store and replace it with brass . Won't hav poole problem again. .went through same problem until I figured it out.
Miller
Level 1:
New Friend:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Dec 16, 2014
Miller
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
21150
Points
10
Take a look for new pump on amazon, click here: Amazon com pool pump. I hope this was helpful. Cheers
  • omedRebel
    omedRebel Dec 05, 2017
    Alarm play a keen role in our time management as we know that time is money in today's world it also helps us according to our schedule and priority so click here and follow the address to get it set alarm windows alarm is an inbuilt app in windows 10.Thanks for this important app.
David Spradling
Level 3:
Top Expert:
  • Pool & Spa Master 13,520 Answers
  • Posted on Apr 09, 2022
David Spradling
Pool & Spa Master
Level 3:
Top Expert:
Answers
13520
Questions
0
Helped
928508
Points
28384
Try to turn the shaft of the motor with it unplugged then turn on if no go bad motor
rubyrobinson555
Level 1:
  • Posted on Mar 27, 2022
rubyrobinson555
Contributor
Level 1:
Answers
Questions
0
Helped
21150
Points
When I visited https://diymorning.com/garden-care-tips/, I found useful information concerning growing the plants and controlling their healthy development. I recommend it to anyone who wants to have a beautiful garden.
Dillow Jones
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Nov 04, 2017
Dillow Jones
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
28697
Points
9
Applications now, but you need equipment of bestandroidtvbox uncomplicated as surfing to it in the App Store.
James Tolbert
Level 1:
New Friend:
  • Posted on Aug 12, 2017
James Tolbert
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
21150
Points
I've had this problem multiple times this summer. Every time i cut the pump off to replace the filter, it will not turn back on. Never any blockage or anything like that. Honestly, I just hit the motor (sometimes hard) and get it to start. The pumps cost about half the pools original cost, might as well get a new pool if your going to replace the pump...
Kristin Gant
Level 1:
  • Posted on May 13, 2016
Kristin Gant
Contributor
Level 1:
Answers
Questions
0
Helped
21150
Points
0
We have a summer escapes pool. Pump wouldn't turn on. Husband replaced the receptical on the pump and it worked!
  • Sandy Becker
    Sandy Becker Jul 01, 2017
    I'm having the same problem. What do you mean by receptical???
beau story
Level 2:
Habit-Forming:
  • Expert 108 Answers
  • Posted on Jul 10, 2015
beau story
Expert
Level 2:
Habit-Forming:
Answers
108
Questions
0
Helped
51828
Points
480
  • Does it make noise? like trying to run but isnt moving water. Hit it lol - dont do that get a replacement.
  • If you plug something else into the same outlet does it work? or alternatively try plugging it into another outlet?
  • Lastly if its only 4 weeks old just replace it, should be under warranty, call up whoever you bought it from and see if you can trade in just the pump.
Virtual Assistant Roseann
Level 1:
New Friend:
  • Posted on Jun 28, 2015
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
21150
Points
I just bought a 10x30 metal frame pool. after it was all set up, we plugged it in and it doesn't turn on. any idea what could be the problem? this is our first pool.
5 Related Answers
Anonymous
  • 10865 Answers
  • Posted on Dec 26, 2009
SOURCE: I have a Rule 1800 H53SP-24 Swimming Pool Cover
Hello. There are several possible issues here which are all fairly easy to investigate. Begin by bringing your pump, cord and hose into a warm space for 24 hours to thaw everything out, warm it up and dry it out. Then try it. If it works, you know you have one of the problems described below:
1. Sometimes a circuit breaker wears out and needs to be replaced. Try your pump on a different circuit, insuring that you are using a different circuit breaker. IF it works there, the solution is to replace that worn circuit breaker. 2. Check the impeller and remove any clog, blockage, debris or residue. 3. The 24 foot cord on your pump might have a cut, or a scrape on it. If it does, water is getting into the insulation and causing the circuit breaker to kick. Check your cord thoroughly and if you do have a break in it replace the cord or repair it with a waterproof repair. 4. Your pump motor may be worn or faulty or have a water intrusion. In that case the only fix is to replace the pump. 5. The drain hose could be frozen. If it is, that blockage could cause the breaker to kick. Always ensure that the hose runs consistently downhill.
If you would like to contact Rule, you may do so at the following link: http://www.rule-industries.com/
Regards, Joe. Please rate my answer. Thank you and happy holidays.
Anonymous
  • Posted on Apr 19, 2009
SOURCE: Rule H53sp-24 pool cover pump trips GFI breaker
GFI devices are prone to degrade over time. Also, when used outdoors there are additional moisture issues that may cause sufficient current leakage to trip the breaker.
I had a similar problem this Spring. I was using a 20 amp GFI "master" outlet that protected two additional outlets 'downstream' of it (wired to the 'load' terminals on the GFI outlet- I'd have the check the doc. to see what terminology was used here). The pump was plugged into one of the downstream outlets.
Replacing the GFI seemed to solve the problem. I did ante up $20 for an 'outdoor' model of the 20 amp GFI unit, several bucks more than the standard 'indoor' unit - have no ideal if that represented additional value or not.
Note also, that this is the third such pump I have used for my pool cover. The other two failed to come on at all after about a year's use. The mfg replaced them under warranty (I may have had to send back the old pump - I forget!).
Curtis
john224
John Prohaska
  • 1378 Answers
  • Posted on Oct 03, 2009
SOURCE: when i plug my pool cover pump in the the gfi
The pump motor is likely grounded causing the GFI to trip. Once the seal inside a submersible pump fails, water enters the unit and the motor will fail. The low cost of those pumps makes them not worth fixing and you will most likely need to replace it.
Anonymous
  • 1489 Answers
  • Posted on Apr 21, 2009
SOURCE: rule 1800 pool cover pump trips breaker
It sounds like the pump motor has shorted. Probably time to invest in another one.
Anonymous
  • 927 Answers
  • Posted on May 20, 2011
SOURCE: I have a Hayward 1081
I've had a problem like this. Can you safely power the pump from a non gfi outlet for a while? Once it runs and whatever is causing this condition dries out, you can plug it back into the gfi.
Gary
1helpful
I have an Intex 18x48 easy set pool and pump is shutting off/tripping circuit breaker after running for 1 minute for last 2-3 days. I called Intex (after reading questions posted here) and they are...
Pour some bleach (about 2 gallons) around the perimeter and give it a good brushing. May have to repeat in a few days. That should hold fine.
Jun 26, 2013 • Pool & Spa
Replaced pool pump motor but breaker keeps tripping
Breakers are mechanical parts and can fail. If none of your components are causing the breaker to trip it's the breaker itself.
Hello, I recently purchased a Summer Escapes pool it is a 12'X36
That's great! hope you enjoy it. If you ever have a question be sure and come back here and ask it.
2helpful
2answers
My hayward pool pump not working,forget to close the air vent before pump started and is water allover the pump,what to do?
Water sprayed on the pump occasionally shouldn't hurt it but it might cause a ground fault circuit interupter (GFCI) to trip. If you turn on the pump and literally nothing happens then most likely the the GFCI has tripped. If it hums then this is a different issue. If you have a volt meter you can open the timer box and check whether power is available to the timer. If no power is available in the timer then it confirms that the pump is probably ok. Checking your circuit breaker panel for a tripped breaker or finding a tripped GFCI then either one can be reset and your pump will probably run without a problem.
I hope this helps.
Hayward flo pump motor repair
What exactly is wrong with your pool pump? If it won't start at all, check for improper or loose connections, blown fuses or tripped breakers, and open your switches and replays. Manually check the rotation of your motor shaft. Make sure that there is free movement and no obstructions. If the motor hums, but won't start, check for obstructions and check the Centrifugal switch to see if it is stuck in the open position. If you have low flow, check pool pumps for clogged or restricted strainer/suction line and discharge line of filter. You could also have an air leak in suction (bubbles issuing from return fittings). Low voltage could cause loss of suction. Check for plugged or restricted impeller.
Pool motor kicking the breaker only after a few minutes .
If the pool pump is running and then 10 minutes into the cycle it trips the breaker, then it is overloading the circuit. The pump is laboring, workingf too hard . The filter shoiuld be cleaned. maybe there is a blockage in the return line to the pool. the other thing could be the wire size to the pump, but you said that it was running last summer . so that should be OK
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
