Plasmafix.com suggest is the burned yppd-jo18c on the y sustain board, please let me know where to find it. Thank you
SOURCE: Screen went black, found blown FS2 on Y sustain board, replaced
Same thing happened to me. I called HP, and they said that they knew about this issues since about 2006-2007, and had been fixing it for customers up until 6 months ago. Now? You're out of luck. HOWEVER, I'm committed to getting their attention on their forums. Join the fight!
http://h30434.www3.hp.com/psg/board/message?board.id=Other1&thread.id=548
SOURCE: I replaced the module on YSUS board and replaced
Usually, when you replace Y-sustain board, for older plasma, they suggest to replace both Ydrive board (up and low). And sometimes, Z-sustaint.
Im not sure your are an expertise in this matter so be very careful when you open a TV because hasardous voltages can kill you in the worst escenario.
If you are not, don't work on your TV. It will be your sole responsibility.
Check ships on Y drive board (both board are installed on the right side of Y-sustain. They have square black ships that used to get bad. If they don't have aluminum cooler on them, you can see if they are burned or have holes on them. Old plasmas use to have issues with those boards. Before you installed the Y Sustain you should check Ydrive boards. Maybe you damage the Y Sustain because the Y drives weren't good.
Try to replace the fuse, disconnect the Ydrive from Y Sustain, turn on TV and check for voltages on Y sustain (panel has a sticker with each voltage). Hope you didn't damage Y sustain and can find Ydrive board to fix your TV.
And REMEMBER, you can kill yourself when you work on TVs.
