SOURCE: Gaggia Platinum Swing
Sometimes if you, turn the machine on without the unit in place it will reset itself, and if on the brew unit the arrow is pointing to the N, then you should be fine, however if the arrow is doing its thing and the gears do not line up then you might have to take it in to get it reprogrammed.
SOURCE: HOw do I remove the
If it's stuck, watch this
http://www.youtube.com/watch?v=NV_TppITQZI&feature=related
Testimonial: "Great video, even if not my exact problem. Definitely would buy from you guys again, a quality approach to problem solving. NWT"
SOURCE: When Gaggia has finished brewing the group head is full of water
check silenoid valve maybe he dont release pressure
SOURCE: i have gaggia brera and after brewing a cup the
Try to descale your machine, use descaling tablets or descaling powder.
SOURCE: Gaggia brera, coffee beans compartment is full of
I have the same problem. Not a solution, but you can still take the ground beans and brew coffee, using the pre-ground compartment.
